SolaraGuy.com • View topic - warning light
warning light
warning light
Postby houtrd00 » Tue Feb 14, 2006 9:26 pm
i got to work and noticed i have a amber light on. left of the seatbelt light, under the c from the temp gauge. i dont get off work till 53am so i dont have time to mess with it. does anyone know what this light is telling me
thanx
houtrd00
Postby SleeperSolara » Wed Feb 15, 2006 7:54 am
What the shape of the warnin' light.
Will have to look when i drive home to see the gauge.
Postby NeFaRiOuS_SLE » Thu Feb 23, 2006 4:22 am
Is it the same light that comes on when you crank the ignition (but turns off once you release the key)? Kinda looks like a car with 6 lines coming from the top half of it (3 on each side)?
If that's it, that's your "rear light out" indicator. If it comes on when you're shifting in reverse, a reverse light is out. Turn signal = Turn signal out (which is also indicated by faster than usual blinking). Tail-light when braking = brake light; when parking or headlight is on = marker. Note it doesn't detect license plate bulbs or any of your front lights (unless I'm mistaken).
Also keep in mind that a burnt light might be harder to spot than a normal light since Toyotas have the ability to switch output to the next working light (e.g. my mother's Camry's front signal burnt out and it still blinked using the less-intense parking light)
Postby SleeperSolara » Thu Feb 23, 2006 7:56 am
Or it could be that the prongs insdie the socket is loose.
Dad's and Grandpa's Camry's do that for the turn signal.
When the light thingy goes on; on the dash and then we check it all teh lights in the back light up like normal.....
MAybe we could wire the license plate bulbs to the turn signal or back-up light to light up on the dash to tell us if it burnt?????
Postby houtrd00 » Thu Feb 23, 2006 7:18 pm
thanx guys for all ur help
i went and checked and it was just a 3 dollar brake light bulb
houtrd00
Postby MCOjerry » Thu Feb 23, 2006 7:23 pm
NeFaRiOuS_SLE wrote:Is it the same light that comes on when you crank the ignition (but turns off once you release the key)? Kinda looks like a car with 6 lines coming from the top half of it (3 on each side)?
Do all Solaras have an indicator that tells you when you have a light out?
Postby bluesolara » Thu Feb 23, 2006 7:25 pm
MCOjerry wrote:Do all Solaras have an indicator that tells you when you have a light out?
All cars in general have a brake light or any light indicator.
2001 Indigo Ink Pearl SE
God bless.
bluesolara
Postby WTF?? » Thu Feb 23, 2006 7:28 pm
I know for sure that Gen 1 - 1.5's do have that indicator, but for the Gen 2's, you may want to refer to your manual
Usually youll spot the light when you turn your key to the accessory option
Retired... its been fun Image
WTF??
Postby NeFaRiOuS_SLE » Thu Feb 23, 2006 11:20 pm
If the Gen2's have an optional tire pressure monitoring system, I'm sure that it'll probably have it (but you never know). Also bluesolara, not all cars have it; it's usually on midsize and above cars (like my 2004 SenCrap never had one, but it ironically still had a low washer fluid warning).
Postby Mossy » Thu Feb 23, 2006 11:22 pm
My mom panics when that light comes on in her camry. Forgets everytime.
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
