SolaraGuy.com • View topic - Tire size for 16" OEM Alloys
Postby widow's son » Tue Jan 21, 2003 10:23 am
I finally found 16"OEM alloys w/tires. The wheels currently have 215/55/16 tires on them. Is this the correct size?What is the widest tire size I can fit on these wheels?
widow's son
Re: Tire size for 16" OEM Alloys
Postby Flipside909 » Tue Jan 21, 2003 10:30 am
widow's son wrote:I finally found 16"OEM alloys w/tires. The wheels currently have 215/55/16 tires on them. Is this the correct size?What is the widest tire size I can fit on these wheels?
215/55/16 is the widest. BTW, use the search feature next time. thanks!
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby cdssolara » Wed Jan 22, 2003 12:33 pm
Actually, you can put 225/55/16 tires on the stock wheel, but it pinches the tire somewhat, and causes the sidewalls to bulge a little. I know people who are using that combination, and they seem to be fine with it. Personally, I don't think it looks right, and I would wonder if the tires are wearing correctly. I would agree with Flipside that you would be better off not going wider than 215.
cdssolara
Postby happy_aggies » Wed Jan 22, 2003 1:32 pm
I was using 225/55/16 and it went fine.
As cdssolara said, the sidewalls is a bit buldge.
The tires wear pretty even,
however you can see that the middle thread wear off a bit more than the side.
happy_aggies
