SolaraGuy.com • View topic - Fuel Injector Cleaner
Postby drock03 » Thu Feb 16, 2006 10:05 am
Anyone know what brand fuel injector cleaner the mechanics use to flush the system. I watched them do it at juffy lube, but couldn't see what they used for cleaner. I wonder if its over the counter stuff or some high potency stuff???
drock03
Postby TadS » Thu Feb 16, 2006 10:34 am
We do it where I work, but it's a more complete system clean. It's not over the counter stuff. It involves chemicals through the air induction and fuel system. It's not really a flush at all, just allot of powerful detergents to clean out deposits and carbon buildup.
TadS
Postby SleeperSolara » Thu Feb 16, 2006 11:21 am
Try usin' SeaFoam, or B&N cleaner.
Use a whole can before you fill up though.
Postby onefiend » Thu Feb 16, 2006 9:29 pm
STP Fuel Injection cleaner and STP Throttle Body spray is all you need. Or you can go with other brands, they're all similar.
JiffyLube charges like $95 for this service, it's ridiculous.
2007 Camry SE V6
onefiend
Postby NVDIS1 » Fri Feb 17, 2006 8:36 am
Toyota has their efi injector cleaner: part#08813-00080 which we sell for $11.95. Must add only when tank is half full per directions on can.
