SolaraGuy.com • View topic - Dying Starter?
Dying Starter?
Dying Starter?
Postby boneezy » Thu Feb 16, 2006 7:23 pm
Recently since the start of the new year, whenever I go to turn my car on, there is this rapid clicking noise, its almost like sticking a straw in the blades of an electric fan.
anyways, my car would still turn on after the crazy clicking but then all of my radio presets would be reset but all my other electricals still work.
I dont think its my battery (though I bought it from toyota 3yrs ago) because with my key in the on position my radio and cabin lights still work. do i have the right diagnosis?
if so, how much will it cost + install?
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby '00vegas-solara » Sun Feb 19, 2006 8:56 pm
Hey whats up fellow Las Vegen.
I have found out the hard way that batteries dont last very long here due to the Summer heat so I change them every 2 years regardless. It cant hurt to throw a new battery in there and maybe that will solve your trouble. Good Luck.
'00vegas-solara
Postby Strider327 » Tue Feb 21, 2006 8:26 pm
That is the truth. Its the battery....
Strider327
Postby Akui » Wed Feb 22, 2006 12:00 am
Although it may very well be the battery you might want to check the connection points on your starter as well. A friend of mine had his Avalon's starter's contacts go bad. Simple job to fix em; buy a kit with the new connections ($20 i think), and simple rachet tools to replace.
Akui
Postby bassthrive » Thu Mar 30, 2006 10:02 am
Something to add, since I have been experiencing a related problem. Roughly every 1 out of 8 times I turn the ignition to start the car, the starter "stutters" and takes a half second longer than usual for the engine to turn over.
I also get the occasional headlight/dash dimming on bass hits.
Is my cheap Costco Exide Classic 72 battery to blame for this? Will the problem be solved if I go out and buy a fancy Optima?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jai_Jai_Binks » Thu Mar 30, 2006 10:39 am
bassthrive wrote:I also get the occasional headlight/dash dimming on bass hits.
^^ now that sounds more like a dying alternator problem to me!!
Just take it to autozone and have them check both the battery and the alternator. Worst case scenario, you will eliminate whats not wrong with your car! It could be a the starter...but my hunch from your above comments its the alternator and connection thingie (whatever they are really called)
Users browsing this forum: Google [Bot] and 13 guests
