SolaraGuy.com • View topic - Wiper Arm
Wiper Arm
Wiper Arm
Postby xlxdarkmarinexlx » Sat Feb 18, 2006 3:25 pm
I want to Adjust the wiper arm on my car and it sits a little bit to high for my taste, not clean at all, i took the bolt off from the wiper arm but it wont even budge i dont want to break anything but i want to adjust it a little lower so it looks more flush and cleaner...
Saepe Exertus, Semper Fidelis, Frater Infinitas Often Tested, Always Faithful, Brothers Forever
CPL*HUEY MWSS 473(-), MAG 47, 4th MAW
www.myspace.com/nwhuey
xlxdarkmarinexlx
Postby SleeperSolara » Sat Feb 18, 2006 5:25 pm
After you get the bolt off, you will have to push the arm alittle bit and them you can take it out and adjust it to your taste.
The arm is held by a spring so you have to push the arm near the hinge and it will straighten out and then you can pull it off.
Hope this helps.
