SolaraGuy.com • View topic - Sway bar = true or false
Postby Solara916 » Thu Feb 23, 2006 8:01 pm
I just got my car back from a REAL autoshop. (My dad actually gave in and had my car looked at by someone else) He said, that the mechanic said that it wasn't either of my struts that were making the funny noise that was coming from the back of my car. Instead, he said that it was my sway bar. I kinda don't believe my dad, but he said that the mechanic told him that I will constantly have this problem with the sway bar coming loose if I keep my 18's on my car. It sounds like total bullshit, but I wanted to come on here to ask if anyone else has had an issue with this. I don't see how the tires can affect the sway bar and make the sway bar come loose.
Any feedback would greatly be appreciated.
Solara916
Postby WTF?? » Thu Feb 23, 2006 8:04 pm
thats TOTAL BS....
what shop did you have the car taken to? that way i tell everyone NOT to go there
Retired... its been fun Image
WTF??
Postby DaTwUnKrAziEpInOy » Thu Feb 23, 2006 8:08 pm
Umm.....yeah........ Completely BS, Your wheels can't affect maknig the sway bar come loose....even if your wheels are out of balance, they'll only warp your rotors. By the way...what kind of sounds are you getting from the rear of your car ???
DaTwUnKrAziEpInOy
sway bar
Postby Solara916 » Thu Feb 23, 2006 8:09 pm
It was some small shop here in Sacramento. I actually do trust them.
Well here's a little more info to the story. My car is due for some new tires, and my parents are supposed to buy them, but my dad is a little tight with the $$ when it comes to tires, and he doesn't want to spend the $100+ on each tire. Instead he wants me to put the stock 15's back on so that he doesn't have to pay so much.
I came on here to ask because since the accident, my car hasn't been the same, so I wanted to see if my dad was bullshiting me or if he was really relaying a true statement from the mechanic.
Solara916
Postby Solara916 » Thu Feb 23, 2006 8:13 pm
The sound was of something, banging against metal. The sound only happened when I went over bumps or whenever my car was joggled around. The weird thing was, you could totally tell what side of the car the noise was coming from, so that's why I assumed it was the struts. I couldn't think of anything that would be able to come loose like that.
My dad and his friend were the ones that installed my struts in the back , and they didn't have a torque wrench or air gun, so it was tightened by hand. I assumed that because it wasn't a "professional" job, that my struts were coming loose because of that.
Solara916
Re: sway bar
Postby WTF?? » Thu Feb 23, 2006 8:17 pm
Solara916 wrote:I came on here to ask because since the accident, my car hasn't been the same, so I wanted to see if my dad was bullshiting me or if he was really relaying a true statement from the mechanic.
I think your dad got the mechanic into it too... due to the fact that hes the one forking out the money to buy tires, as parents they dont like spending on stuff they dont have to like your upgraded 18" tires....
if i were you.... id get a job and take it into my own hands... but of course parents will say if you get a job, then you should save and all that crap
:agrue:
good luck
WTF??
Postby Solara916 » Thu Feb 23, 2006 8:20 pm
HAHA...hey...they were the one's that told me to quit my jobs, move back home and go to school full time. I did get a part time job, but they told me to quit. I can't argue with them since I'm living under their roof again.
I had the wheels way before all this happened, so it ain't may fault. :)
Solara916
Postby WTF?? » Thu Feb 23, 2006 8:21 pm
hahahahah thats your fault for moving back home LMAO
WTF??
sway bar
Postby Solara916 » Thu Feb 23, 2006 8:25 pm
Ya it is, but at least now I don't have to worry about rent, bills, or utilities. Well, at least not for awhile. :)
I'm sure my my mom will buy them for me or something. There's no way I'm putting the 15's back on. I worked too hard to get those 18's to just put them in to storage.
Solara916
Postby DatSRBoi » Thu Feb 23, 2006 8:27 pm
Check your rear strut mounts.
Postby Solara916 » Thu Feb 23, 2006 8:30 pm
Well the noise is gone for now. Whatever the mechanic did, solved the issue.
Solara916
Postby Jai_Jai_Binks » Fri Feb 24, 2006 10:07 am
Lube the rsb??? I know some of us do have that noise from the rsb...nothign a little lub'ing can't solve!
Re: sway bar
Postby SpikedMantis » Fri Feb 24, 2006 4:22 pm
Solara916 wrote:Well here's a little more info to the story. My car is due for some new tires, and my parents are supposed to buy them, but my dad is a little tight with the $$ when it comes to tires, and he doesn't want to spend the $100+ on each tire. Instead he wants me to put the stock 15's back on so that he doesn't have to pay so much.
Go with Kumho Ecsta 712 Supras. There about 100 each and are a good value.
SpikedMantis
Postby Turbosolara » Fri Feb 24, 2006 4:55 pm
my guess is your offset was bad, so the mechanic change your camber to a bit negative and fix the problem.
however, it is common that trd swaybar making noise (just need good lubrication)
Re: sway bar
Postby Solorange » Fri Feb 24, 2006 11:16 pm
Solara916 wrote:It was some small shop here in Sacramento. I actually do trust them.
Here you go http://www.tirerack.com/tires/tires.jsp ... es&place=2 this is what im buying as soon as I get the cash. Its $425 with 4 tires, road hazard package, and shipping. It may be a bit more for you in the shipping because you live in cali. Oh yeah if you have a trd sway bar its probably just creaking. Mine does it. Ive lubed up the bushings like 2 times now and it just started creaking again.
