SolaraGuy.com • View topic - pulled a couple codes yesterday
Postby BradOwens » Sat Feb 25, 2006 9:44 am
so i was comin home from taco bell and i started goin up a hill. so i gave it a lil gas and all of a sudden the rpms wouldnt climb at all. i mean it had trouble getting to 40mph. the check engine light also started flashing so i was like crap. so i take it to autozone with my dad and they plug it up and my car ended up pulling 6 codes :o
two were for multi engine misfire. two for cylinder 1 misfire. and two for cylinder 4 misfire. we ended up ordering an ignition coil and installed it today. fixed everything which is good. im gettin up there at 88K miles and i was wondering at 90K is there any major type of service like spark plugs or timing belt or something like tht. thanks
BradOwens
Postby Solorange » Sat Feb 25, 2006 11:27 am
Those hills will do that to you, I was going to Steak and Shake one night and I was going up a hill and my coilpack went out as well.
Re: pulled a couple codes yesterday
Postby StockSolara » Sat Feb 25, 2006 11:48 am
BradOwens wrote:so i was comin home from taco bell and i started goin up a hill. so i gave it a lil gas and all of a sudden the rpms wouldnt climb at all. i mean it had trouble getting to 40mph. the check engine light also started flashing so i was like crap. so i take it to autozone with my dad and they plug it up and my car ended up pulling 6 codes :o
At 60k is when you're suppose to change the plugs and 90k is when you change the timing belt, water pump, radiator flush, and etc
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SleeperSolara » Sat Feb 25, 2006 1:32 pm
Dude you haven't done your timin' belt yet????
I've already done mine at 78k miles.
You need to get the timin' belt done ASAP since you reachin' 88k already.
Postby Solorange » Sat Feb 25, 2006 2:50 pm
^ that makes me feel better too, I thought people say its best to replace your timing belt at 60k but the dealership said you cant wait later than that. My car is at 85k right now. This spring I planning taking care of the timing belt and water pump.
