SolaraGuy.com • View topic - Different pattern??
Different pattern??
Different pattern??
Postby Nyyankees3511 » Sun Feb 26, 2006 5:02 pm
After i installed my hids i noticed that when i put my lights on against a wall form about 15 feet away the driver side has a different pattern than the passenger side. Is that normal?
Nyyankees3511
Postby NeFaRiOuS_SLE » Mon Feb 27, 2006 9:09 pm
Show us a pic... Sometimes even in standard Halogen, there's a "pattern" designed to reduce glare for oncoming traffic while still providing maximum range. Here's an example with 1 headlight:
________,------------
_________________
Re: Different pattern??
Postby bluesolara » Mon Feb 27, 2006 9:32 pm
Nyyankees3511 wrote:After i installed my hids i noticed that when i put my lights on against a wall form about 15 feet away the driver side has a different pattern than the passenger side. Is that normal?
Yeah it's completely fine, the driver's side is actually made (the housing) to shoot a little lower to not get into the oncoming traffic's eyes or shoot glare at them. Just re-aim them to be sufficient and don't worry about the both of them being identical as long as their about the same height, the pattern will definitely be different.
2001 Indigo Ink Pearl SE
God bless.
bluesolara
Postby bluesolara » Mon Feb 27, 2006 9:33 pm
NeFaRiOuS_SLE wrote:Show us a pic... Sometimes even in standard Halogen, there's a "pattern" designed to reduce glare for oncoming traffic while still providing maximum range. Here's an example with 1 headlight:
_________________
That's an exaggerated depiction, unless you have projectors the cutoff isn't going to be that clean, mine aren't even that clean w/ HIDs so don't worry if it's a little blurred as long as they're basically about the same height s'all good.
God bless.
bluesolara
Postby NeFaRiOuS_SLE » Tue Feb 28, 2006 12:13 am
_________________
Yeah it was a bit exaggerated, but it's not like ASCII drawings do too much justice either.
