SolaraGuy.com • View topic - CEL code p0171...
CEL code p0171...
CEL code p0171...
Postby xSolarax » Thu Mar 02, 2006 11:01 pm
Just recently my cel light came on and I went to Advanced Auto and got the code analyzed on a DTC....I was just wondering if anyone else here has has had P0170 and what your experience was. The slip said (system too lean (bank 1).... I know what bank 1 means and not getting enough fuel. I was thinking it was either it was a bad 02 sensor or a bad fuel injector. thx :drinking:
Gen 1 TRD Lip Kit, TRD RSB, TRD Struts, Tein S-tech, CP-E, CC, Kicker Comp
-->>PART OUT DECEMBER 10, 2008<<--
xSolarax
Postby Fratsgotasolara » Fri Mar 03, 2006 6:10 am
clean or replace your mass air flow sensor thats normally where that code comes from
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
Postby SleeperSolara » Fri Mar 03, 2006 7:22 am
Also try fule injector cleaner too.
That should clear it up too.
That way you elimnate any guess you think you could be wrong.[/i]
Postby BradOwens » Fri Mar 03, 2006 9:01 am
Fratsgotasolara wrote:clean or replace your mass air flow sensor thats normally where that code comes from
yep. same thing happend to me altho i never replaced it. when the code was on i about half floored it and i think there might have been some build up on it and it blew off. but id try cleaning it first before replacing it.
BradOwens
