SolaraGuy.com • View topic - Right headlight and right fog won't turn on
Postby pvu » Sat Mar 04, 2006 10:17 pm
When I took my Solara for a drive tonight, I realized my right headlight and my right fog didnt light up. I thought it couldn't be the bulbs because I've just put some silverstars a month ago. Can this be the fuse? I've read on the manual and the fuse for the front headlight is 10amp and 15 amp for both the foglights. But if the fuse is blown for my foglights, both of them won't light up, right? Only my right side wouldn't turn on. Any suggestions?
pvu
BTW, I have a 99 solara
pvu
Postby jhenty » Sat Mar 04, 2006 10:25 pm
sounds like a fuse, check the manual for whatever side fuse. There is fuses for left/right sides. Theres a lot of fuses for the lights period.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby bluesolara » Sat Mar 04, 2006 11:09 pm
Check fuses first, they're like 85 cents for a million. Then if that fails bulbs, if that fails then wiring. I had to fix my fogs so that's how I approached it.
2001 Indigo Ink Pearl SE
God bless.
bluesolara
Postby Whatever » Sun Mar 05, 2006 4:20 am
that happened to me two days ago, and i just turn it off and turn it back on again then it worked.
Whatever
Postby xsolara33x » Sun Mar 05, 2006 12:05 pm
check the fuse bro..
raphael
xsolara33x
Postby pvu » Sun Mar 05, 2006 3:52 pm
The fuse on the headlight burned and the bulb on the headlight won't light up because of condensation. There so much water in my fog light. I have to seal it when it gets warmer. Thanks for the help guys.
pvu
