SolaraGuy.com • View topic - Installing new Silverstar
Postby AzN_DrAgoN48 » Sun Jan 26, 2003 11:13 am
I just got some Silverstars and i got it right one in fine. But the left one is kind of a pain. The battery is in the way. so shoule i remove the battery or just try to move around it somehow?
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Re: Installing new Silverstar
Postby Yanks0114 » Sun Jan 26, 2003 11:18 am
AzN_DrAgoN48 wrote:I just got some Silverstars and i got it right one in fine. But the left one is kind of a pain. The battery is in the way. so shoule i remove the battery or just try to move around it somehow?
You should be able to change the bulbs without having to remove the battery. I know exactly what you mean about it being a pain though. Make sure you don't touch the glass on the bulb. If you still can't get it then take the battery out, but its unnecessary
Lights
Postby mattacosta » Sun Jan 26, 2003 11:19 am
It was a pain in the ass for me, the battery was in the way too much so I moved it and just put the headlight in and than replaced the battery.
1999 Toyota Solara V6 SE
All Stock... For Now
http://www.cardomain.com/id/99solarama
mattacosta
Postby SKYravefever » Sun Jan 26, 2003 12:56 pm
You shouldn't really need to move the battery to change your bulbs, but it'd be much more easier if that was done. Definately move it when you're adjusting them though. It's just one screw, and all you need to do is push the battery back just a little bit.
SKYravefever
silverstar
Postby Danny » Sun Jan 26, 2003 10:43 pm
how did the ehadlights turn out .. look wise???
Danny
Postby AzN_DrAgoN48 » Mon Jan 27, 2003 1:41 pm
its white than the oems but not a great amount. i think it'll do without spending the 500 for the hid
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby xyntax » Mon Jan 27, 2003 1:49 pm
You know what? I thought it wasnt much of a change too, but after friends and relatives of mine saw my car at night or when I'm driving behind them they asked me if I ever had someone get upset at me for aiming high beams at them. And one told me that they were too white. Oh well :roll:
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby AzN_DrAgoN48 » Mon Jan 27, 2003 4:28 pm
is it just me or does the right ones less white than the left one?
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby SKYravefever » Mon Jan 27, 2003 4:57 pm
Hmm... could be the fact that you may need to adjust them to for them to look even.
SKYravefever
Postby AzN_DrAgoN48 » Mon Jan 27, 2003 5:03 pm
how do you adjust them? the right one is a pain... damn battery
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby krook » Mon Jan 27, 2003 6:04 pm
i think it's supposed to be like that. the driver's side and pass. side are not at the same level. it's not a significant notice, but it's there.
krook
Postby Blaze » Mon Jan 27, 2003 6:11 pm
its for oncoming drivers
Blaze
Postby SKYravefever » Mon Jan 27, 2003 8:45 pm
There should be a right hand flare on DOT headlamps. If you park your car perpendicular to a wall, the pattern should look like this.
__/ __/
Of course, the flare's are not as dramatic as my picture, but it's there. That is used to light up the signs along the side of the road at night here in the States.
BTW, both sides are to be leveled. For more info, get a Haynes/Chilton manual for that
SKYravefever
Postby AzN_DrAgoN48 » Mon Jan 27, 2003 8:51 pm
no but like the light is more yellow that the other one
8000k Osram HID
Silverstars fogs
Clear Corners
JBL BP600.1
AzN_DrAgoN48
Postby SKYravefever » Mon Jan 27, 2003 8:53 pm
The angle of the bulbs affect how the color of the light looks, since the bulb may light up different parts of the headlamp compared to the less-yellow side.
SKYravefever
