SolaraGuy.com • View topic - Help!!!
Help!!!
Help!!!
Postby mattacosta » Sun Jan 26, 2003 8:49 pm
Ok Heres My Project I want to do!!!
I want to Run Dual Exhausts, I should be able to slip the stock ehaust into a Y pipe and than run the dual exhausts correct? Anybody who has done this please help.. I am going to have 2 Stock Exhausts, not 2 aftermarket..
Pics or a Diagram would help ALOT thanks!!
1999 Toyota Solara V6 SE
All Stock... For Now
http://www.cardomain.com/id/99solarama
mattacosta
Re: Help!!!
Postby Yanks0114 » Sun Jan 26, 2003 8:54 pm
mattacosta wrote:Ok Heres My Project I want to do!!!
Well you best of luck, its going to be a long and expensive project. I tried to do it a while back and i gave up after i got many quotes of over $1000. You will see no performance gains. Since there is not enough room underneath the driver's side of the car, you will either have the pipe hanging low or you'll have to use oval pipe. Either way you won't be able to lower your car. Also in order to get it to sit symetrically you'll need to move your stock muffler. Mr. B. From teamsc3.com has this setup and it looks great, but when he tried to put his body kit on he ran into big problems. The tips were venting hot exhaust right into the body kit. I would not reccomend dual exhaust unless you are up for it. Use to search function to read up about it.
