SolaraGuy.com • View topic - hub bore?
hub bore?
hub bore?
Postby PEITRUS » Mon Mar 13, 2006 6:59 pm
hub bore on 16x7 wheels 40mm offset
options: 56.1mm & 67.1mm & 73mm
which would fit?
PEITRUS
Postby PEITRUS » Mon Mar 13, 2006 7:44 pm
wow no replies yet huh.
well i know that most, if not, all toyotas with 5x114.3 lug pattern have a hub bore of 60.1mm. with the options stated above i am not sure which would fit and am very perturbed about this issue. any help would be great.
PEITRUS
Postby hskrsolara » Mon Mar 13, 2006 7:53 pm
give a shout to discounttiredirect.com. those guys helped me out before. wish I could help out more.
hskrsolara
Postby cklinh » Mon Mar 13, 2006 7:57 pm
as long as it's larger than the hub size on the car, you can get adapters (hub rings).
cklinh
Postby PEITRUS » Tue Mar 14, 2006 1:30 pm
at my local auto parts store?
PEITRUS
Postby Mandarinsolara » Tue Mar 14, 2006 1:34 pm
what in the hell are you putting on 16's?
i hope not a solara
Mandarinsolara
Postby cklinh » Tue Mar 14, 2006 1:43 pm
Probably at a tire/wheel store. Or online at ebay, etc...
cklinh
