SolaraGuy.com • View topic - 2002 V6 Tranny
2002 V6 Tranny
2002 V6 Tranny
Postby scottie » Wed Jan 29, 2003 1:52 pm
I recently changed the transaxle fluid, the book calls for 5 qts but only about 3 qts drained out so I refilled it to the proper dip stick level. What is the tranny fluid capacity.
scottie
Postby Guest » Wed Jan 29, 2003 4:55 pm
Its probably five. The other two quarts are in the torque converter and really wont drain. If you filled it up to the correct level you should be fine.
Guest
fluid level
Postby wizman » Wed Jan 29, 2003 6:07 pm
it should take 4-4.5 qts of trans fluid and make sure you are using the correct type of fluid,the spec usually includes the drain for the diff fluid also. be careful some diffs have a seprate fill!
wizman
