SolaraGuy.com • View topic - grill removal/install
Postby woa_its_j3ff » Wed Mar 29, 2006 1:59 pm
Just a simple question for a noob haha.
How do you remove the factory black grill?
And how do you install a new aftermarket grill ? (like the silver mesh kind)
any response is appreciated. :) thanks guys.
Re: grill removal/install
Postby Jon11582 » Wed Mar 29, 2006 2:53 pm
woa_its_j3ff wrote:Just a simple question for a noob haha.
Removal - three bolts with the hood popped, then two clips on the inside, and some elbow grease.
New grill - If its not OEM, probably alot of zip-ties.
2000 Black Solara SE
Jon11582
bolts
Postby woa_its_j3ff » Wed Mar 29, 2006 5:06 pm
to loosen these bolts on the grill or w/e, where are they located?
Postby ThatVietGuy » Wed Mar 29, 2006 5:50 pm
Open the hood, they're right on top
ThatVietGuy
Postby woa_its_j3ff » Sun Apr 16, 2006 2:24 pm
ive tried, wont get off?... pics could help.
Postby krook » Mon Apr 17, 2006 11:59 am
use a ratchet with a 10mm socket. after the bolts are removed, tilt your head so you are looking at the bottom of the grill from the inside (engine bay looking out).
you'll see 2 clips at the bottom of the grill. gently push them up and pull the grill out. again...use some force!
krook
Users browsing this forum: Google [Bot] and 38 guests
