SolaraGuy.com • View topic - Relays for upgraded lights
Postby widow's son » Thu Jan 30, 2003 9:23 am
Is it necessary to add relays when upgrading headlight bulbs? I did this on my Corrado and the improvement was awesome. If a relay is needed does anyone have a diagram? Thanks.
widow's son
Re: Relays for upgraded lights
Postby Flipside909 » Thu Jan 30, 2003 12:58 pm
widow's son wrote:Is it necessary to add relays when upgrading headlight bulbs? I did this on my Corrado and the improvement was awesome. If a relay is needed does anyone have a diagram? Thanks.
Wiring harnesess are not necessary unless you plan to run a higher wattage bulb. With OEM or Silverstars, harnesses are not needed.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby SKYravefever » Thu Jan 30, 2003 1:02 pm
Hope this helps
http://faq.auto.light.tripod.com/headlamp-harness.html
, and as Ryan mentioned, if you're running higher wattage bulbs (which I think that's what you meant by "upgrading" your bulbs), then you'll need the harness. Otherwise, on stock wattage bulbs, 55W, you won't need it.
SKYravefever
