SolaraGuy.com • View topic - speedo gear replacement?
Postby needmorecrap » Wed Apr 12, 2006 2:40 pm
I want to get my wife some new rims and tires(225/40/18's) but dont want her speedo to be off. In the haynes manual it shows a vehical speed sensor with a gear, so it is like my jeep that i can replace this gear and fix it or does it need to go to the stealership and have them calibrate it? Thanks
needmorecrap
Postby calreef18 » Wed Apr 12, 2006 2:58 pm
That size wheel and tire is gonna be pretty much on the money for speedometer, shouldn't really be off.
calreef18
Postby needmorecrap » Wed Apr 12, 2006 3:01 pm
actually it will be 4% off, so when the car says i'm doing 60 i'm really going 62.5 Its not that much of a difference but i dont want extra miles on the car.
needmorecrap
Postby xavier » Wed Apr 12, 2006 3:22 pm
wouldnt that put less miles on the car? If the speedo says your going slower than you really are, your mileage will be slighlty less than whats actually on your car. Right?
xavier
Postby Nyyankees3511 » Wed Apr 12, 2006 4:01 pm
Mileage wont be affected, totally different sensor.
Nyyankees3511
Postby Jon11582 » Wed Apr 12, 2006 5:16 pm
needmorecrap wrote:actually it will be 4% off, so when the car says i'm doing 60 i'm really going 62.5 Its not that much of a difference but i dont want extra miles on the car.
Its actually 1.6% if its got stock 15s, slightly more with stock 16s.
At 60MPH on the speedo, youll be going 59MPH
Anything below 3% is considered negligable and does not require correction.
http://www.1010tires.com/TireSizeCalculator.asp
Stock is 205/65/15 or 205/60/16
2000 Black Solara SE
Jon11582
Users browsing this forum: Google [Bot] and 38 guests
