SolaraGuy.com • View topic - WHATS THE DIFF
WHATS THE DIFF
WHATS THE DIFF
Postby Jaxsen » Fri Apr 14, 2006 7:28 am
WHAT IS THE DIFFERENCE BETWEEN GEN.1 AND GEN.1.5 ? I'M A NEW SOLARA GUY.
STOP POSTING IN CAPS! when you post in caps, it means you are yelling -admin
Jaxsen
Postby SleeperSolara » Fri Apr 14, 2006 7:39 am
Gen 1.5
Gen 1
Postby RichD978 » Fri Apr 14, 2006 7:47 am
dont have time to type it up but someone explain the gen 1.5 trd kit on a gen 1
RichD978
Postby Jaxsen » Fri Apr 14, 2006 7:58 am
Is it a performance kit or because its a convertible that makes it a GEN1.5?
Jaxsen
diff
Postby Sentinel » Fri Apr 14, 2006 8:11 am
The headlights/grille and the taillights are different. The 1.5's taillights have rounded shapes inside them, whereas 1's are straight.
I am not aware of any mechanical differences, although I drove a 1.5 convertible and it's v6 sounded a bit throatier than mine.
Sentinel
Postby Nyyankees3511 » Fri Apr 14, 2006 8:22 am
Gen 1.5s have vvti on the 3.0 v6 so it added some more hp and torque.
Nyyankees3511
Postby SC V6 » Fri Apr 14, 2006 8:35 am
gen 1 is better
SC V6
Postby Hsakuragi » Fri Apr 14, 2006 8:48 am
why don't u read the posting instructions before asking questions in caps?
1.5 does NOT have vvti for the v6
Hsakuragi
Postby indiglosolara » Fri Apr 14, 2006 8:51 am
Nyyankees3511 wrote:Gen 1.5s have vvti on the 3.0 v6 so it added some more hp and torque.
The gen 1.5 v6 doesn't have VVT-i. The Gen 1 and gen 1.5 v6 motor is the same.
The gen 1 has a 5s-fe 2.2L i-4 while the gen 1.5 has the 2az-fe 2.4l i-4 engine with VVT-i.
The diff between the gen 1 and gen 1.5 are mostly cosmetic...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Jai_Jai_Binks » Fri Apr 14, 2006 8:55 am
i assumed we had a sticky somewhere for newbies!
Postby RichD978 » Fri Apr 14, 2006 8:58 am
lay off guys. we were all newbies once
RichD978
Postby SolaraBlue » Fri Apr 14, 2006 9:04 am
99-01 (gen 1)
02-03 (gen 1.5)
04-06 (gen2)
gen1
gen1.5
as you can see the difference is mostly in the front bumper, headlights, and grille. not major differences but you can see them. also the taillights are a different too.
gen1
gen1.5
hope this hels! and welcome! post some pix when you can.
Postby Jon11582 » Fri Apr 14, 2006 9:52 am
Exteriors been pointed out already.
V6 was the same, I4 engine went from 2.2L 135HP 5SFE to the 2.4L 160HP 2AZFE w/ VVT-i.
Trunk release became a push button electronic release from the pulley lever, and got moved to inside the glove compartment from under the driver seat.
Wood trim went from Burlwood to Mustard,
1.5 also got wood trim around the shifter, gen1 is black around the shifter.
I think fog lights became independent on gen 1.5 (dont need the headlights on to turn on fogs). Also the gen 1.5 shared foglights with the Gen6 Camry (02-06).
Headlights went from a dual filament bulb (9003) to one bulb for high (9005), and one bulb for low (9006).
2000 Black Solara SE
Jon11582
Postby Nyyankees3511 » Fri Apr 14, 2006 2:02 pm
My bad i was thinking about the es300.
Nyyankees3511
Postby QuickSEV6 » Fri Apr 14, 2006 2:29 pm
Jon11582 wrote:Wood trim went from Burlwood to Mustard,
Nope. I have a gen 1. I have burlwood around the shifter. Not black.
Users browsing this forum: Google [Bot] and 17 guests
