SolaraGuy.com • View topic - Clear plastic vinyl near door
Postby DougSolara » Fri Apr 14, 2006 11:39 pm
Hey guys,
I'm still getting used to my Solara and have a quick question. On both sides, near the doors there is a small clear vinyl thing? Almost like a protective layor, it also has a little bit of dirty under it around the edges.
I dont have my digi camera with me, so this is the best I can do visually.
Heres a dealer pic of my car, the circle outlines the area on both sides where this thing resides. The green squiggly is supposed to represent what it looks like.
What is it?
Can/Should I remove it?
Anyone to clean it if i shouldn't remove it?
Much thanks,
-Doug
DougSolara
Postby SleeperSolara » Sat Apr 15, 2006 8:36 am
Naw you don't need to take them off.
Postby krook » Sat Apr 15, 2006 3:33 pm
ask your dealer what it is. if it's on both sides...maybe someone put it there for a purpose....?
if anything, take it off. i don't have that on my solara
krook
Postby DougSolara » Sat Apr 15, 2006 4:28 pm
hmm yeah, I might give take it up there speak with him.
It looks like it is protecting that small L shaped area from scratches but that makes no sense to me, I cannot logically see how that space is more vulnerable than others. Im also not good with cars so that might have something to do with it. :)
2000 Toyota Solara SE (V6) DWP
DougSolara
Postby RichD978 » Sat Apr 15, 2006 5:09 pm
i had it on mines but when i got into an accident on my passenger side they took that one out. I still have one in my drivers side. let me know how it goes i want to take it out because it faded to yellowish.
RichD978
Postby krawzyazn » Sat Apr 15, 2006 6:55 pm
they come stock with them on
Postby trdkamuri51o » Sat Apr 15, 2006 7:12 pm
lmfao none of you figured it out yet????????
OMFG CLEAR BRA!!!!!!!
its to protect it from rockchips as that area is prone to getting nicked.. look on most SUVs specifically the older landcruisers on the rear fender wells same thing...
i cant belive no one figured that one out????
trdkamuri51o
Postby RichD978 » Sat Apr 15, 2006 7:14 pm
^^ I know that but I'm wondering how I can get it off ?
RichD978
Postby trdkamuri51o » Sat Apr 15, 2006 7:42 pm
^razor blade hahahah
(if u think thats the way then sell your car and buy a civic, wait rich your halfway there)
trdkamuri51o
Postby 1st Gen Sol » Sat Apr 15, 2006 8:21 pm
As "trdkamuri51o" stated its a clear bra type protective layer that protects that part of the car as it tends to get nicked.
I removed mine after it started to turn yellow. You can use a heat gun to remove it b/c you don't need it. Just depends on you, if you feel at ease leaving it on, just clean it, if not remove it.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby RichD978 » Sat Apr 15, 2006 8:26 pm
wouldn't a heat gun ruin your paint?
RichD978
Postby Nyyankees3511 » Sat Apr 15, 2006 8:31 pm
Well yea if you keep it there and hold it in one spot for a long time.
Nyyankees3511
Postby 1st Gen Sol » Sat Apr 15, 2006 8:34 pm
^^^^ Exactly
Keeping it on one spot will ruin your paint. Moving it back and forth to heat up the glue will not.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby JAYDEE23 » Sun Apr 16, 2006 6:33 am
imagine how hot your paint gets in the sun after a couple hours in the middle of summer with no breeze :D
dont get it hotter than that
JAYDEE23
Postby SolaraFun » Sat Apr 22, 2006 12:11 pm
Mine ar e still on my car too. They do protect the car and paint, but if mine were dingy yellow, I'd remove them. I think they really don't do anything much more than being part of how the car is shipped right after production. Has anyone had the problem that when they did remove them 4 years later that the paint was brighter under them than the car to make a noticiable difference? Like you could tell that there was something there? That would be my only good reason to take them off...
Huh, something to ponder... :agrue:
~KT~
2002 Solara SE V6
+ 2 12" Sony Xplod Subs w/800w Amp
- Reverse Indiglo gauges
+ Carbon Fiber bezel & ebrake cover
"+" mesh grill
SolaraFun
