SolaraGuy.com • View topic - o/d
o/d
o/d
Postby woa_its_j3ff » Mon Apr 17, 2006 12:09 pm
hrmm i know this is prolly a dumb question but, what exactly is Overdrive anyways? and what is the difference between wehn it's "on" and "off" ?
Postby krook » Mon Apr 17, 2006 12:12 pm
as far, as i can remember, "overdrive" is actually just pushing the gas pedal harder to go into the 4th gear.
when you push in the O/D button, "O/D OFF" appears on your instrument cluster, this puts you back in 3rd gear.
and you'd only use it when you needed more pulling power, like going up a hill for example.
krook
Postby theprodigy79 » Mon Apr 17, 2006 12:19 pm
It originated as a 4th gear added onto a three gear tranny that was used for maintaining the best fuel efficiency at cruising speeds. Third gear was considered "Drive", so they termed it "Over Drive"... When pulling a load or driving up hilly terrain you generally disabled it.
Currently (since auto tranny's are usually 4 gears +) it just referrs to the highest gear on an auto tranny... When you're cruising at around 60 disable it and you will feel the car downshift into third (Drive). When you re-enable it your car will shift back into 4th (Over Drive).
theprodigy79
Postby woa_its_j3ff » Mon Apr 17, 2006 12:21 pm
sweeeeeeeeeeeeeeeeeet 8)
Postby dominoSLEV6 » Mon Apr 17, 2006 8:06 pm
Go on the highway and hit about 80 MPH with the O/D off. Now, paying careful attention to your RPMs, turn it on. It's like a 5th gear on your autobox and will mostly save you gas and put less strain and wear on your engine.
-chris
dominoSLEV6
Postby woa_its_j3ff » Mon Apr 17, 2006 8:08 pm
dominoSLEV6 wrote:Go on the highway and hit about 80 MPH with the O/D off. Now, paying careful attention to your RPMs, turn it on. It's like a 5th gear on your autobox and will mostly save you gas and put less strain and wear on your engine.
-chris
so basically does o/d (ON) usually help or o/d (OFF) ?
Postby theprodigy79 » Mon Apr 17, 2006 8:17 pm
On current cars it's pretty much just a lable for the highest gear. For the most part keep it on; it should only be turned off if you are pulling a load or riding up steep inclines (or if you are racing you may want to leave it off as well).
theprodigy79
Users browsing this forum: Google [Bot] and 17 guests
