SolaraGuy.com • View topic - my bad luck continues.... 4 quarts low in 2.5K miles :(
Postby pervo » Fri Apr 21, 2006 8:35 am
one thing after another with this car
now my dealer tells me it was 4 quarts low
best case scenerio its a valve cover and it will cost 1,500!
cant i buy a rebuilt engine for around these $ ?
are any of tthe possible scenerios do it yourself friendly?
pervo
Postby Sap Z » Fri Apr 21, 2006 8:46 am
wat was 4 quarts low?
SapZ
V6 SE DWP
Sap Z
Postby theprodigy79 » Fri Apr 21, 2006 8:52 am
his oil...
You can get a low mileage engine at a junk yard for dirt cheap and do the swap yourself if you have the time / resources... It's a pain in the ass, but I did it with my Celica and it saved me a ton (only cost $600 total with engine, new fluids, new gaskets, new filters, new plugs, new wires, etc...)
theprodigy79
Postby pervo » Fri Apr 21, 2006 9:21 am
i was quoted 1450 at my door 6 month warrenty
how doable is it to swap this engine myself?
i am sure i can look and find a cheaper engine but i think this is as good as ill get
pervo
Postby theprodigy79 » Fri Apr 21, 2006 9:58 am
You'll need someone to work with (three people if you don't know anyone with a substantial amount of strength), a few ramps or a lift, a cherry picker, around 16-18 hours of time to put into it (since you've never done it before), room enough to have both engines and all parts available, and LOTS of patience (I marked EVERY SINGLE hose, nut and bolt). It's doable, but it ain't fun. I did it cuz they wanted another $1,200 to put it in for me...
theprodigy79
Postby pervo » Fri Apr 21, 2006 10:07 am
did you work with a hanes/chiltons manual or did you just match things up
pervo
Postby SleeperSolara » Fri Apr 21, 2006 11:30 am
That will help alot man.
Yeah i suggest 3 people and a cherry picker and lots of space to work around.
Good luck.
Postby Turbosolara » Fri Apr 21, 2006 11:45 am
ok i am not too sure what are you talking about..
your engine oil is 4 quart lower than at begging? what year and engine you have? most likely is your oil pan (if it drips). just check your own engine and see which part is wet. if it is too dirty, just use simple green to clean up all the dirt and check back later
Postby theprodigy79 » Fri Apr 21, 2006 12:50 pm
pervo wrote:did you work with a hanes/chiltons manual or did you just match things up
Absolutely, the Chiltons was my lord and savior!
theprodigy79
Postby pervo » Fri Apr 21, 2006 7:19 pm
Turbosolara wrote:ok i am not too sure what are you talking about..
99 sle v6
from last oil change (2.5k mi) i lost 4 of five quarts
i am fairly certain it is a piston ring as every morning big clouds of smoke come out the exaust
3 weeks ago i had to replace the plugs because one had entirely gummed up and was severely missfiring
i will check the valve seals and compression but i think i am pretty much screwed
still owe for three years on it and my credit card is maxed out thanks to recient rpairs already
it has been a lemon from day one, cant say i will be buying toyota again
pervo
Postby TadS » Sat Apr 22, 2006 1:17 pm
I would check the compression before I started dropping any money. You can get a compression tester for 30 – 50 dollars. I had a seal on an oil filter fail, which lead to severe leakage. Make sure that you know what wrong before you pay anybody big cash for work, as with gas prices being high, and that effecting business, some mechanics might be prone to jumping to ideas on what needs to be fixed / replaced, just to make some work.
TadS
Postby Strider327 » Tue Apr 25, 2006 11:22 am
Big clouds of smoke huh? Either the rings are bad or the headgasket is gone. If your losing that much oil I would consider looking at the tube seals as well. Under the valve head. Just open it up and check it to see whats wrong. Hopefully it ain't too bad, but it'll probably end up costing you around 400-500 bucks in parts and labor. Good luck
Strider327
Postby variant » Tue Apr 25, 2006 2:41 pm
my last car did the same thing, cept it wasn't dripping that fast and left a cloud only if I punched it, it was the headgasket or a valve seal
variant
Postby pervo » Thu Dec 14, 2006 1:22 am
looks like im getting a shortblock rebuild after persuing the dealer for 4 months thanks to a new manager (who doesnt work there anymore! good timing lol)
pervo
Postby Sp33d » Thu Dec 14, 2006 1:52 am
well i got to this post a little to late, but a member on here is actually selling his engine block,
PYTHONJOSH
he has a manual transmission and was selling it for 1500 i think. but i gues since you are getting an engine rebuild, you are good to go.
-mark
Sp33d
