SolaraGuy.com • View topic - Speaker size??
Do u have a upgraded System?
Yes
12
60%
No
8
40%
Total votes : 20
Speaker size??
Speaker size??
Postby solaraguy777 » Sat Feb 08, 2003 6:33 pm
Hi i need to know on the solara if that 6x5 and 6x9 speakers fit in the solara???
Ram air intake w/ k&N filter, Trd exhaust,
Hp racing evo 18's, Tokico/Eibach combo.
solaraguy777
Postby impactX » Sat Feb 08, 2003 9:48 pm
The rears are 6x9s.
impactX
Postby Peter » Sun Feb 09, 2003 2:33 am
6.5 front and 6x9 rears is correct. not 6x5, but 6.5
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby Peter » Sun Feb 09, 2003 2:35 am
Visit Black Sheep
Peter
Postby solaraguy777 » Sun Feb 09, 2003 7:54 am
aight thanks for all the help
solaraguy777
Postby TITO » Sun Feb 09, 2003 11:32 am
Hey, say if you mount bigger speakers say in your trunk can you disconect the rear 6x9's and connect to any size bigger without having to add an amp?
99 V6, LOWERED, COOL CUSTOM GRILL, TINTED WINDOWS, CUSTOM FRONT BUMPER, WHITE 17" WHEELS, BODY KIT, CLEAR CORNERS, INTAKE WITH K&N.
TITO
Postby TadS » Sun Feb 09, 2003 12:34 pm
Not sure what you are trying to do here.
If you're hooking up to another size of full range, mid range (crossed), or component speakers you should be all right, as long as they don't have a funky ohm load.
On subs, I wouldn't bother. The 1st reason is due to lack of power. Even a powerful CD player will only give you 22-35watts RMS, while most subs want like 75-100 watts Min RMS. They would work, however I don't think you would be very happy with the output. 2nd you need a crossover for subs. I have seen some decks with built in crossovers, but in this case it comes back to power.
TadS
Postby solaraguy777 » Sun Feb 09, 2003 1:03 pm
I have two pioneer 12's and i got infinity 6.5 and 6x9 speakers do they have to hook up to the amp or r they fin on the reg amp that the car comes w/? and do u recomend getting anouther battery for the speakers alone?
solaraguy777
Postby Yanks0114 » Sun Feb 09, 2003 1:09 pm
solaraguy777 wrote:I have two pioneer 12's and i got infinity 6.5 and 6x9 speakers do they have to hook up to the amp or r they fin on the reg amp that the car comes w/? and do u recomend getting anouther battery for the speakers alone?
Infinity reference or perfects. If they are reference hook them up to the stock stereo, if u bought the perfects which i doubt, get them an amp. Also the subs WILL need an amp to run
Postby TadS » Sun Feb 09, 2003 2:08 pm
Like Yanks said, you need an amp for subs. With the extra battery it depends. I don't know if that amp has a current regulator or not and that is sometimes a factor. I am drawing 400 watts@4ohm RMS on my system on a completely stock electrical system, no capacitor or anything, and my OEM battery and alternator are still ticking away after 80k with my stereo. If you notice minor light fad when the bass hits you might want to look into a capacitor or a yellow top before adding a battery. Also, good quality power and ground wires helps alot! You could also be over driving the amp, that gain knob is not a volume knob :D . Adding a battery can get pretty crazy with the battery isolators and grounding etc. Hope this helps.
TadS
