SolaraGuy.com • View topic - d or 2
d or 2
d or 2
Postby Guest » Sat Feb 08, 2003 9:35 pm
what is the difference between d and 2 on the automatic?
would it be bad on the engine to drive with the switch? on 2 while in residential neighborhoods?
just wondering
thanks
Guest
Re: d or 2
Postby impactX » Sat Feb 08, 2003 9:47 pm
Anonymous wrote:what is the difference between d and 2 on the automatic?
just wondering
thanks
2 = 2nd gear is the highest gear that the transmission will engage
D = 4th gear is the highest gear that the transmission will engage
D w/ OD Off = 3rd gear is the highest gear that the transmission will engage
I don't see why you have to drive on 2.
The only times I would use 2 is when I am AutoX'ing or going down steep hill.
impactX
Postby Yanks0114 » Sat Feb 08, 2003 10:06 pm
2nd gear would keep your rpms really high and waste gas.
Postby krook » Sun Feb 09, 2003 5:21 am
use 2 and L for when you need more "pulling" power...or when going down really steep hills.
otherwise, leave it in D with normal driving. hit the O/D button around 75 or 80mph to kick it in 4th.
krook
Postby solaraguy777 » Sun Feb 09, 2003 1:05 pm
krooked Solara wrote:use 2 and L for when you need more "pulling" power...or when going down really steep hills.
Ur supposed to keep or o/d on at all times not when u got over 75
Ram air intake w/ k&N filter, Trd exhaust,
Hp racing evo 18's, Tokico/Eibach combo.
solaraguy777
Postby pecora55 » Sun Feb 09, 2003 2:16 pm
so lets say i was racing and it was at a track what would i do? take O/D off and start out at low then 2nd then drive and then around 75 hit the od back on? would that work out bettter or what?
Goodbye solara, loved you while i had you :( now into my bros hands, and hello Spec V...BYE BYE SpecV HELLO 04 Maxima ;)
'04 Maxima SE
'03 Sentra SpecV(SOLD)
'99 Solara SLE V6 Auto(SOLD)
pecora55
Postby NASTY » Sun Feb 09, 2003 5:04 pm
pecora55 wrote:so lets say i was racing and it was at a track what would i do? take O/D off and start out at low then 2nd then drive and then around 75 hit the od back on? would that work out bettter or what?
i assume it'd be better, as long as you don't forget to shift
you can hold the gears longer, and downshift yourself
thats basically as close as you can get to driving manual!
'01 SLE V6
NASTY
Postby pecora55 » Sun Feb 09, 2003 5:47 pm
can someone clarify this? what would be best to do...
'04 Maxima SE
pecora55
Postby NASTY » Sun Feb 09, 2003 5:59 pm
well, shifting manually (for the track anyways) because you can downshift for engine braking, powering out of turns (without waiting for the tranny to downshift), and whatever i said before
...or just trade in for a manual!
'01 SLE V6
NASTY
Postby Missay » Sun Feb 09, 2003 6:09 pm
or trying to get up snowy hills or get yourself out of the snow when you're stuck :wink:
Melissa
Missay
SolaraGuy Ambassador
Postby CrazyCraig » Sun Feb 09, 2003 10:14 pm
Not only will driving around in 2nd gear waste gas, but it's also gonna set you up for an early tranny failure. The higher rpm causes your tranny to run hotter and the low speed doesn't allow for proper cooling. Keep it in "Drive".
CrazyCraig
CrazyCraig
Postby Jai_Jai_Binks » Mon Feb 10, 2003 8:45 am
For all those who bought automatics! WAKE UP..you bought an automatic, not a starard/stick! There are limitations to what an automatic can do, playing around too much with the gears w/o any knowledge will reduse life in your tranny!
Postby krook » Mon Feb 10, 2003 12:16 pm
yah, don't do that. i used to do that with my old corodda. i used to even drop it in 2nd when i was going 40 or so. auto's not made for that kind of abuse.
krook
Brake Torque it
Postby Chi Town Solara » Tue Feb 11, 2003 9:09 pm
well if you got an automatic like i did (i am still kicking myself) the best way to get the best launch from a standstill with an automatic is by using something called "brake torqueing" (sorry bout the spelling!) when all the magazines like caranddriver and motortrend test auto cars 0-60 they brake torque it to get a good launch. to do this hold the brake with your left foot, and then get the rpms up to about 3000. release the brake and lay into the throttle. now it does help if u have high performance tires so u get less wheel spin on launch but even with stock u will get better ¼ mile times.
Chi Town Solara
Re: Brake Torque it
Postby Yanks0114 » Wed Feb 12, 2003 2:06 pm
Chi Town Solara wrote:well if you got an automatic like i did (i am still kicking myself) the best way to get the best launch from a standstill with an automatic is by using something called "brake torqueing" (sorry bout the spelling!) when all the magazines like caranddriver and motortrend test auto cars 0-60 they brake torque it to get a good launch. to do this hold the brake with your left foot, and then get the rpms up to about 3000. release the brake and lay into the throttle. now it does help if u have high performance tires so u get less wheel spin on launch but even with stock u will get better ¼ mile times.
Ehh you really don't wanna power brake up to 3000 rpm. Thats ALOT of stress on your tranny. I've been successful at up to 1800rpms, after that i don't wanna risk it. I rarely do it too because its terrible for the tranny.
Anyone wanna explain boost braking?
Users browsing this forum: Google [Bot] and 16 guests
