SolaraGuy.com • View topic - CEL- Code PO446
CEL- Code PO446
CEL- Code PO446
Postby Solorange » Sat May 13, 2006 8:32 am
I was driving home to my parents house this weekend up to Toledo and my CEL came on like two exits before I got home. I ran the code today at autozone and it came up with PO446. Dont have my hanyes manual with me so I ran a search to see if you guys got this code before. You guys got like every code but mine. LOL! But I did find this
P0446 – EVAP System - vent control malfunction
· Same as P0441
P0441 – EVAP Control System - incorrect purge flow
· Open or short in VSV circuit for EVAP
· VSV for EVAP
· Open or short in vapor pressure sensor circuit
· Vapor pressure sensor malfunction
· Open or short in VSV circuit for vapor pressure sensor
· Malfunction in VSV for vapor pressure circuit
· Vacuum hose blocked, damaged, or disconnected
· Charcoal canister malfunction
Just wondering if you guys had this problem before and didnt post it. Your help would be greatly appriciated. If I can fix it myself it would help my broke @ss out. The guy at autozone told me to clean out my fuel system first to see if it goes away. I havent put fuel injector cleaner in for like 6 months so I figured why not. I dont think that will solve the problem. But well see. I did run my fuel tank to just under a 1/4 tank so maybe it sucked something up.
Also whats the VSV?
Any Ideas on how or what to check first would be great. Thanks Hopefully my drive back to Cincy will make it go off.
http://www.solaraguy.org/viewtopic.php? ... hlight=cel
Postby Fratsgotasolara » Sat May 13, 2006 9:12 am
um get a charcoal canister, its the way you get those two codes, its a pain to install on our cars as you have to drop the rear suspension, but seeing your location as kind of nw ohio pm me if you want help or need to get a canister, i got the hook up as i work for the dealer in lima
"You may not know me, But your girlfriend does!" -Delta Chi OSU
Fratsgotasolara
