SolaraGuy.com • View topic - Dyno run
Dyno run
Dyno run
Postby kondo » Mon Feb 10, 2003 3:07 pm
I put my 99 Superchargerd SLE on a dyno to see how much HP I was making. I had denso iridium 22 plugs put in before the run. I also have a Injen intake and a Greddy Evo and the stock pulley. The test was done on a dynopak where they take the rims off and put pole looking things on the hubs that go into a box on each of the front wheels, so ther was no loss caused by slippage on rollers of anything. Anyway here is a print out of the run. The most I was able to get was 186HP and 204Ft/lb. For some reason the chart dips at around 5300 and then peaks out a 6100. Anyone have any idea what is causing this? The guy at the shop thought that the mixture was running too rich right there but I did not have him run a air/fuel test so I'm not sure.
http://www.joshpeete.com/images/dyno2.jpg
Nick
[/url]
kondo
SolaraGuy StickerGuy
Well..
Postby SKYravefever » Mon Feb 10, 2003 5:08 pm
that's kind of disappointing. :-? considering you've got all the basic bolt-ons and the s/c. Time for headers!!! :wink:
SKYravefever
Postby Yanks0114 » Mon Feb 10, 2003 5:31 pm
I'm not familiar with what a dynopak is but your dyno results are extremely low. An auto with no other mods should hit 204-210FWHP plus the greddy and injen. I don't know if you are running too rich, but i think you could be running too lean. I'd upgrade the pulley, get an S-AFC and dynotune it
Postby ICrazyChrisI » Mon Feb 10, 2003 8:10 pm
Wow..on my n/a SLEV6 w/ a Greddy exaust I got 155hp/175lb tq on a Dynojet. Something has to be messed up.
ICrazyChrisI
Postby EricSol » Tue Feb 11, 2003 7:02 pm
You need to dyno again this time checking your a/f ratio. Get a bung welded in b4 the cat so you can get a acurate reading.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby EricSol » Tue Feb 11, 2003 7:03 pm
1999 Solara 296 whp
EricSol
