SolaraGuy.com • View topic - air bag replacing..?
Postby elton123 » Sat May 20, 2006 6:45 pm
If anyone know about air bag servicing, I hit a pole going like 20 mph and so air bags went off, Im thinking about buying them on ebay or junkyard, after I replace them will the airbag light automatically go off? or will I also have to replace the control module.
elton123
Postby NeFaRiOuS_SLE » Fri May 26, 2006 8:09 pm
Whoa, sorry to hear that... Usually it's recommended to change the sensors in case it is stuck in the deploy signal or extra sensitive (e.g. you go over a pothole and it deploys), but I'm not too sure if it's REALLY necessary.
Postby elton123 » Sat May 27, 2006 8:05 am
where the sensors located and how many are there.
elton123
Postby lilm » Sun May 28, 2006 12:09 am
2? i think there in the front on each side there little black boxes
lilm
Postby ASG14 » Sun May 28, 2006 8:39 am
I know in my Gen 3 (92-96 Camry), there is 2 sensors behind each front fender. IF the SRS system is ok, the light should turn off when the car is turned on. The center sensor (under my center counsol) dies, as soon as it was replaced, the light automatically went off. Just be SURE that WHENEVER you work on the SRS system that the battery has been unhooked for at least 10 minutes.
ASG14
Postby elton123 » Tue May 30, 2006 12:51 pm
well since I was in a minor accident, it will be too much time and money to try and replace those sensors, both airbags and diagnostic comp, then hope the srs will stay off, so I will probably just do an airbag deletion of some kind.
elton123
