SolaraGuy.com • View topic - SUPERCHARGER - JUST PURCHASED
Postby gnaw divad » Wed Feb 12, 2003 2:27 am
I just bought the supercharger for my solara and its coming soon!!! I had some questions about the 5.5 and 6 psi pulleys and how they compared to each other. I have heard that there is actually no power difference but ive also heard that the pulleys boost more than they say and there is a power difference. Not sure what would be a better bet for my new charger....
ALSO, I was wondering if they made a tripod for the solara? if so where could i find one?
THANKX IN ADVANCE !!
[/b][/u]
gnaw divad
Postby happy_aggies » Wed Feb 12, 2003 8:29 am
:o a Tripod? Can anyone explain what is that?
happy_aggies
Postby STR8PYP » Wed Feb 12, 2003 9:15 am
There shouldn't be any major difference between the 5.5 and 6psi pulleys...maybe 3-5hp at most.
Never heard of a tripod for a car... ????
SC
STR8PYP
Postby TadS » Wed Feb 12, 2003 11:24 am
Tripod... All I can think is a pod for 3 gauges?
TadS
Postby Yanks0114 » Wed Feb 12, 2003 2:04 pm
TadS wrote:Tripod... All I can think is a pod for 3 gauges?
Possibly, if this is true i've only seen a dual pod gauge cluster for the A pillar
Re: SUPERCHARGER - JUST PURCHASED
Postby cdssolara » Wed Feb 12, 2003 4:46 pm
gnaw divad wrote:I just bought the supercharger for my solara and its coming soon!!! I had some questions about the 5.5 and 6 psi pulleys and how they compared to each other. I have heard that there is actually no power difference but ive also heard that the pulleys boost more than they say and there is a power difference. Not sure what would be a better bet for my new charger....
[/b][/u]
What you've heard about pulleys boosting more than they say refers to spikes of power. It doesn't happen all the time, but for example, occasionally a 6 psi pulley might give you 8 psi in short bursts. I'm not really technically savvy enough to explain why this happens, but perhaps someone else could. In any case, 6 psi seems to be the generally accepted "safe" maximum. I went with a 5.5 psi pulley just to be a little safer. I don't think the difference will be noticeable. I'm very happy with my 5.5 psi. Even with that boost, I have had the Check Engine light go on a couple of times, with a Knock Sensor #2 diagnostic code. Each time, there was no impact on performance, and the light went off within a couple of days on it's own. I have not seen it for several months now.
cdssolara
Postby ICUFG » Wed Feb 12, 2003 5:59 pm
I have a 6.2psi (2.75) and i love it good power and no problems so far, well just a little spark plug issues. No biggie.
ICUFG
Postby Guest » Thu Feb 13, 2003 3:04 am
Sorry for the confusion but by tripid i mean the pillar that holds 3 gauges, like Fuel ratio, oil heat, boost meter etc.
I used to own a mitsubishi eclipse and i had one that fit on the piller to the left of the front winshield, it held 3 gauges. I was wondering if they made one for the solara?
Guest
what i meant was
Postby gnaw divad » Thu Feb 13, 2003 3:05 am
gnaw divad
what i meant was
gnaw divad
what i meant was
Postby gnaw divad » Thu Feb 13, 2003 3:06 am
I also own a mitsubishi eclipse and i have one that fits on the piller to the left of the front winshield, it holds 3 gauges. I was wondering if they made one for the solara?
gnaw divad
Postby gnaw divad » Thu Feb 13, 2003 3:08 am
sorry for the repeats, an error message kept popping up
gnaw divad
Postby happy_aggies » Thu Feb 13, 2003 8:34 am
So far I know, they only make 2 gauge pillar pod for Solara.
PS: You can delete your own post. just click delete/edit button. :D
happy_aggies
Postby DavPak » Thu Feb 13, 2003 9:06 am
happy_aggies wrote:So far I know, they only make 2 gauge pillar pod for Solara.
where can i get one?
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Guest » Thu Feb 13, 2003 9:24 am
burien has them on sale now.
poweredbytoyota.com
jerold
Guest
Users browsing this forum: Google [Bot] and 32 guests
