SolaraGuy.com • View topic - A couple questions..
Postby user99 » Sun Jun 04, 2006 1:22 pm
Can someone tell me the part number for the strut/spring cushions in the rear.
Can someone also tell me what the best replacement OEM springs are.
Thanks
99 Solara SLE V6, Automatic
user99
Postby DaTwUnKrAziEpInOy » Mon Jun 05, 2006 3:19 pm
I'm not following about the best replacement OEM springs ?? Are you wanting lowering springs or do you just want stock ones ??
Look in the For Sale section and you might be able to find some stock springs or aftermarket lowering springs.
As for the "strut/spring cushion" are you talking about the strut mounts or that rubber piece that is seated between the strut seat and the spring ?
DaTwUnKrAziEpInOy
Re: A couple questions..
Postby JavaJoe_2 » Mon Jun 05, 2006 3:26 pm
user99 wrote:Can someone tell me the part number for the strut/spring cushions in the rear.
Thanks
I have a used set with 50k on them.
$100 plus shipping...comes complete with EVERYTHING.
Mounts, springs, struts....complete units.
Got Boost?? :sweet:
JavaJoe_2
Postby user99 » Tue Jun 06, 2006 9:58 am
DaTwUnKrAziEpInOy wrote:I'm not following about the best replacement OEM springs ?? Are you wanting lowering springs or do you just want stock ones ??
I dont want lowering springs.. wouldn't I need different struts ?
I am referring to the rubber piece that is between the strut seat and spring.
user99
Postby JavaJoe_2 » Tue Jun 06, 2006 10:19 am
Here's wher I purchased mine: Conicelli Toyota
Got Boost?? :sweet:
JavaJoe_2
