SolaraGuy.com • View topic - what kinda radar detector should i buy?
Postby michaelwgng » Sun Jun 04, 2006 8:15 pm
what kinda radar detector should i buy? r they even worth it???
Mike
michaelwgng
Postby DatSRBoi » Sun Jun 04, 2006 8:21 pm
You get what you pay for.
Valentine 1
Escort X50
both are very good radar.
Postby Biggi_e » Sun Jun 04, 2006 8:25 pm
valentine 1 is a great radar detector
Postby AznDragonV » Sun Jun 04, 2006 10:31 pm
not meaning to thread jack but...i was jus thinkin bout this today and wat if u buy a radar dectector, and is it possible for them to come out wit new radar bands and then urs wont detect it right?
AznDragonV
Postby xSolarax » Mon Jun 05, 2006 8:27 am
I have a Beltronics Vector 955 R.D. and for me its worked very well... If I decided to get a new radar I would probably go with a top end Bel... on a side note i thought this was kinda cool...
http://www.radarbusters.com/products/coatings/veil.asp
Wonder if it works...?
Some radar detectors you can send in to get updated.
Gen 1 TRD Lip Kit, TRD RSB, TRD Struts, Tein S-tech, CP-E, CC, Kicker Comp
-->>PART OUT DECEMBER 10, 2008<<--
xSolarax
Postby xSolarax » Mon Jun 05, 2006 8:38 am
There is suppose to be a new band called Ku that radar guns will have, it is already being used out of the US, but most likely will make its way here... Should look into the BEL RX65...
xSolarax
Postby Jai_Jai_Binks » Mon Jun 05, 2006 8:43 am
xSolarax wrote:If I decided to get a new radar I would probably go with a top end Bel
Same here
Postby PXLpainter » Mon Jun 05, 2006 10:10 am
From everything I've read online, most "experts" seem to point to the Valentine 1. Why should I consider anything else (except for price)??
Postby cklinh » Mon Jun 05, 2006 10:12 am
^^^ Well... maybe for looks... because the Valentine 1 looks BUTT-UGLY... (still, it'd probably be the one I'd get)...
cklinh
Postby Hybridlude97 » Mon Jun 05, 2006 6:39 pm
I had a beltronics for awhile. My only complaint was the bracket to mount it to the windshield. After a few months it started to rattle then the radar stated sagging. Overall the acutal radar detector is great. But if price doesnt matter, get a V1 hands down.
02 Solara 2AZ 5sp
Hybridlude97
Postby jimhild » Mon Jun 05, 2006 10:49 pm
V1 hands down. We have two, both have been updated with all the new changes. Even though the initial price is higher the arrows make up the difference, plus the remote to hide the lights. Great radar detector.
Jim & Susan Hildebrand
Scottsdale, AZ
jimhild
Postby K@$H » Mon Jun 05, 2006 11:49 pm
I also have the V1 and it has saved me a few time man. The arrows are an amazing feature, and have picked up cops way behind that i can't even see.
2004 Solara SE
K@$H
Postby Too Bzy » Wed Jun 14, 2006 9:15 am
Valetine 1 hands down. I've had others and it's the best. I don't care if some people thinks it's ugly, it works.
AznDragonV wrote:not meaning to thread jack but...i was jus thinkin bout this today and wat if u buy a radar dectector, and is it possible for them to come out wit new radar bands and then urs wont detect it right?
Valentine is the only one that can be sent back to Valentine to be upgraded as the tech changes. The other reason I bought mine.
Charles "Cee-Jay" Hughes
99 TRD Solara S/C LB GP Ed. 23 of 35
86 Supra w/ 6M-GTE
Too Bzy
Postby TripleBlack » Wed Jun 14, 2006 3:43 pm
I heavily recommend Escort's Passport 8500 (x50). First of all, though, you should know that your only options are that and the Valentine V1. If you used to be considering anything other than one of those two, stop. Those are your choices. A or B. Escort or Valentine.
That said, in every test I've ever read, the V1 seems to out-perform the 8500 in distance of first detection (which is, of course, extremely important and pretty much the whole point) BUT only just barely so. The 8500 is usually right on its heels, while all other competition is left trailing in the dust.
So, with detection distances being as close as they are, it's going to come down to feature set and product design. In my personal opinion, that's the 8500 by a long shot.
If attractiveness matters, the 8500 destroys the V1. There is no contest. The 8500 is probably the best looking detector on the market and the V1 is probably the worst.
If features matter, the V1 does offer those little directional arrows which tell you if your strongest threat is in front of you, behind you, or off to the side (though it does not specify which side). Some say that's an excellent piece of information. I say, who cares? If there's a cop nearby, I don't care in what direction he's in. He's nearby. That's enough. I'm slowing down now.
The 8500, on the other hand, offers a much more inforative display of multiple threats. Whereas the V1 will count the number of signals it's currently picking up, it only displays the signal type and strength of the strongs. The 8500 (when set to "Expert" mode) will indicate the type and strength of ALL signals. This is absolutely invaluable information, once you get good at reading it.
Also, the 8500 is cheaper. I think it's $300 the V1's $400. In both cases, the unit is going to pay for itself in time regardless - it's merely a matter of how much time.
Whether you buy the V1 or the 8500 (because, remember, there are no other options), here's a quick lesson on different radar signals...
X-Band: This is the cheapest type of radar, and because of that, it's also the most common. This is the EXACT same signal motion detectors above the doors in supermarkets use, so those are going to get picked up too. X-Band is also the easiest of the bunch to detect, so you can usually pick this stuff up a mile away. A weak signal is either a nearby store or a distant cop. If you're in a town, assume the former, but on a highway, assume the latter.
In 'city' mode, the 8500 will automatically ignore weak X-band signals. In 'highway' mode, it will alert you of everything it sees. In 'auto' mode, it will try to determine if you're in a city or on a highway based on the number of X's it sees, and inform you accordingly.
K-Band: This is a little more expensive (for police), a little more rare, and a little harder to detect. It's also used occasionally (rarely) in motion detectors, so it might be a false alarm, but most likely is not. Never ignore K-band detections; no detector on the market will either.
Ka-Band: This is the most expensive of the radars and the hardest to detect. I wish I could say it was rare, but it really isn't. Although, it may depend on the budget of the police departments in the towns you cruise though. In any case, Ka-band radar is your worst enemy. The 8500 and the V1 are the ONLY (am I sounding repetative yet?) detectors on the market that can pick up Ka at a distance large enough to be useful. Be cautious of even the weakest Ka detections. The cop could be lurking right around the corner. The odds of this being a false alarm are extremely slim.
Laser: This shiznit is crazy 'spensive and next to impossible to detect. Quite frankly, any detector (my dear ol' 8500 included) which claims it can detect Laser before you've been hit with it is probably lieing. Unless you're the one that got shot, that beam is nearly invisable. Thankfully, Laser is incredibly expensive and super-rare. You don't have much to worry about, unless your detector tells you. Because, if it knows there's Laser in the area, the cop has already shifted out of Park.
VG2: A few years back, police figured out a way to tell if you're using a radar detector or not. It's called VG2 and I haven't the faintest idea how it works. The radar detector companies responded by learning how to pick up VG2. Basically, they built a radar detector detector detector. When VG2 is spotted, the device turns itself off automatically, as to remain stealthy. Just about everything on the market has this capability, but I've never actually seen it happen with my 8500. Maybe the fuzz 'round these parts don't use VG2? I dunno.
Wow, so this turned out to be one long post. Damn. Well, I hope it was useful. Happy shopping. And, slow down. ;)
TripleBlack
Postby WTF?? » Wed Jun 14, 2006 8:13 pm
Who knows what the "Pop" feature is on the 8500??? i forgot what it was
Retired... its been fun Image
WTF??
