SolaraGuy.com • View topic - Suspension Woes *pics added*
Postby SC V6 » Thu Jun 08, 2006 9:45 am
So I recently had an allignment and was told that my rear driver side tire couldn't be adjusted and was bent so teh tires would have irregular wear. It is only off by like 4% so its nothing huge, but I notice the angle on the wheel and want to fix it.
If I replace my struts and springs and remove my monsterous subs from the trunk would that help?
Best place for Struts/Springs?
SC V6
Postby 2kSoulara » Thu Jun 08, 2006 9:59 am
I have a set of tokico struts and tein springs all new and in box for sale. I decided not to lower so I'm selling 350 shipped. Im in new jersey. PM me if you have any questions
2kSoulara
Postby SleeperSolara » Thu Jun 08, 2006 10:32 am
Check the bars:
The ones that run from left to right in the picture.
Check if they are straight it not then go to the salvage yard and get some from them.
And that should fix it.
Postby SC V6 » Thu Jun 08, 2006 10:53 am
you have the tokico blues?
SC V6
Postby SC V6 » Fri Jun 09, 2006 9:00 am
Are you selling the Tokico blues w/ genuine tein springs?
Also, those are control arms right (in the picture)?
SC V6
Postby SleeperSolara » Fri Jun 09, 2006 11:04 am
SC V6 wrote:Are you selling the Tokico blues w/ genuine tein springs?
The arms the run left and right and an angle is the adjustment bar.
The bar closest to you is probably bent, check that.
The one in front of that is just a bar for placement.
The bar closest to you in the pictures i believe is for alignment.
The rear control arm in the thing in the bottom left of the picture, that lets the wheel part move forward and back.
The bar that runs left and right lets the wheel move left and right in the picture view.
To check that adjustment bar wit thread in the middle; you have to take the wheel off, and look at it that way, and check it in the view of my picture.
Postby SleeperSolara » Fri Jun 09, 2006 11:09 am
The rear control arm in the one in the left on the bottom.
You need to check the adjusment bar closest to you in the picture i posted.
You need to check in different angles.
If you just check the bar if it straight like in my picture you won't see it bent forward or back, you need to take off the wheel and check it like this:
That is what it's suppose to look like.
Not like this.
You need to check if from the rear of the car like how i took my picture.
Postby SC V6 » Sun Jun 11, 2006 1:35 pm
So I checked them with a ruler, and none of them are bent... what else could it be that is making it bend in like that? Its the driver rear, and none of those are bent. Everything seems fine.
have a bad spring? or what?
SC V6
Postby SleeperSolara » Sun Jun 11, 2006 5:42 pm
SC V6 wrote:So I checked them with a ruler, and none of them are bent... what else could it be that is making it bend in like that? Its the driver rear, and none of those are bent. Everything seems fine.
That could be it.....
But i don't think a bad spring would not let you align it though......
Postby DatSRBoi » Sun Jun 11, 2006 5:51 pm
How in the world do you bend that thing?
Postby Nyyankees3511 » Sun Jun 11, 2006 8:11 pm
Could be the strut mount.
Nyyankees3511
Postby SC V6 » Mon Jun 12, 2006 6:41 am
They couldn't align it.. the driver side rear wheel is tilted so it will be having irregular tread wear
SC V6
Postby SleeperSolara » Mon Jun 12, 2006 10:40 am
Can you take a picture so i can see waht it looks like.....
"DatSRBoi" to answer your question, i have no freakin' idea.
Postby SC V6 » Mon Jun 12, 2006 10:49 am
yeah... I'll take some pictures...
I'm sure I know what caused it...
WHen I was 16 I took a turn and turned too tight, adn the rear wheel was drug over a curb... that was it.. was going maybe 25-30... Ill take pics tonight...
SC V6
Postby SleeperSolara » Mon Jun 12, 2006 11:17 am
SC V6 wrote:yeah... I'll take some pictures...
There we go, i knew somethin' had to happen for it not to be straight.
Might be that eth wheel hub on the rear driver side is f-ed up.....
