SolaraGuy.com • View topic - Both Fog Lights Out???
Postby Taps06 » Thu Jun 15, 2006 5:38 pm
Check it, both my fog lights are out, I changed the bulbs, nuttin, checked all the fuses, nuttin!!! Are there any relays I should be maybe looking into? Headlights are fine. Anyone, feel free to comment and give your opinion on a possible solution! Greatly appreciated!
Taps06
Postby krook » Thu Jun 15, 2006 6:24 pm
check the plugs then. the last time both my fogs were out, i was putting in an HID kit and i forgot to "up" my fuse to 35AMPs; the fuse kept blowing.
if both fogs are out, chances are the fuse is blown. check the fuses behind the coin pocket to the left of the steering wheel on the knee panel.
krook
Postby WTF?? » Thu Jun 15, 2006 11:02 pm
Seeing that you are new to the forum, did you just buy the solara?If the solara is new to you, is it possible that you didnt know of the separate switch for the fogs to turn on?
also like krook mentioned, if you installed a particular type of HIDs, you may experience a fault in fogs not working at all.
Keep in mind, the fogs only have the option to turn on/off when the headlights are on (not the Daytime Running Lights). If you want the fogs to turn on without having the headlights on, you will have to rewire some things to have Independent Fogs... there is a tutorial on how to do this in the Tutorial section of the forum.
Heres my pic:
Thanks again to pythonjosh
Retired... its been fun Image
WTF??
Postby Turbosolara » Fri Jun 16, 2006 12:02 am
you need to use the 12v tester to track down. maybe you just had a bad switch? you know how to turn on foglight right?
Postby Taps06 » Sat Jun 17, 2006 12:03 am
Just for info, I've had the Solara since 03! Now is there another switch other than the combination switch that turns on headlights and fog lights? If there is, I am unaware of this switch! As far as the fuses go, fuses are good (behind coin holder compartment). Bulbs are 9006 (Sylvania), same as OEM.
Taps06
