SolaraGuy.com • View topic - CEL for the Spadman
CEL for the Spadman
CEL for the Spadman
Postby ~Spadwaller~ » Thu Jun 22, 2006 9:49 pm
I noticed the CEL about a week ago disappeared then came back I went to Autozone and borrowed one of their scanners. I got back this....
p1410
p1411
p0442
Any ideas on how to fix them?
~Spadwaller~
Postby DatSRBoi » Thu Jun 22, 2006 10:32 pm
Hahah I guess your days come now too after being boosted eh?
Postby ~Spadwaller~ » Thu Jun 22, 2006 11:08 pm
Say it aint so!!!!
~Spadwaller~
Postby ---CAMRAZY--- » Fri Jun 23, 2006 12:03 am
P0442 – EVAP System - small leak detected
· Same as P0440
P0440 – EVAP System Malfunction
· Vapor pressure sensor malfunction
· Fuel tank cap cracked, damaged or incorrectly installed
· Vacuum hose blocked, cracked, torn or disconnected
· Hose or tube blocked, cracked, torn or disconnected
· Fuel tank damaged
· Charcoal canister damaged
Above is one,
but here is a Link
http://www.solaraguy.org/viewtopic.php? ... 1411+p0442
Here is another one
P1411 EGR Valve Position Sensor Circuit Range/Performance
here is that link
P1410 EGR Valve Position Sensor Circuit.
Postby ~Spadwaller~ » Fri Jun 23, 2006 12:36 am
sounds like dealer time :(
~Spadwaller~
Postby ---CAMRAZY--- » Fri Jun 23, 2006 7:05 am
Your welcome maricon
Postby Jon11582 » Fri Jun 23, 2006 7:43 am
seems like they are all fuel tank related.
Tighten your gas cap, clear the codes, and see if it comes back.
2000 Black Solara SE
Jon11582
Postby ~Spadwaller~ » Fri Jun 23, 2006 8:59 am
CamrySE-soCALlara wrote:Your welcome maricon
Thanks, Puto!
~Spadwaller~
Postby Hsakuragi » Fri Jun 23, 2006 10:02 am
puto maricon ..sounds better?
Hsakuragi
