spark plug wires??
hey guys i need your input about spark plug wires.. What would you guys recommend?
- socalisolara
- SolaraGuy Driver
SleeperSolara wrote:If you're NA than got wit 7mm. RJ hooked me up wit them.
If you S/C'ed than 8mm or 8.5mm is good.
QuickSEV6 wrote:SleeperSolara wrote:If you're NA than got wit 7mm. RJ hooked me up wit them.
Why would it matter if your NA or supercharged? Spark is spark regardless of how much pressure is in the cylinder.
Now plug size. That would matter. That determines the location of the spark.
SleeperSolara wrote:QuickSEV6 wrote:SleeperSolara wrote:If you're NA than got wit 7mm. RJ hooked me up wit them.
Yeah but it depends on how much volts the spark plug wire can give the spark plugs.
Mandarinsolara wrote:you will lose a bit of response with the stock crappy distributor and the largest wires around.
