SolaraGuy.com • View topic - Timing Belt/Spark Plugs
Postby JMSinMaryland » Sun Feb 16, 2003 8:05 pm
Does the Supercharger have to be removed to change the timing belt? I've heard the S/C doesn't need to be removed for the plugs but it's easier. I guess if my mechanic could do a S/C install with EBC changing the plugs w/SC on shouldn't be a problem. Again does the S/C need to be removed for timing belt? Also programming instructions for RS3200 key fob please. Jon.
JMSinMaryland
Postby Yanks0114 » Sun Feb 16, 2003 9:25 pm
Not sure about the timing belt. Are you at 60k miles allready?
For the RS3200 the ECU is located underneath the center console.
You will need to unbolt everything and the ECU is under there. You will need a socket and a phillips head. Set the key to on, hit the program button once and the red LED should light up. Press the key fob button and it should give you a confirmation tone
Postby DavPak » Mon Feb 17, 2003 7:12 pm
yanks, that programming method works on some models, i sent him the instructions for programming it using a combination of locking/unlocking the doors, opening the door and stuff like that. it came straight from the Solara repair manual. maybe he didn't get it??
'02 Solara S/C'ed V6 5-spd
DavPak
Users browsing this forum: Google [Bot] and 19 guests
