SolaraGuy.com • View topic - HELP RPMS GOING NUTS NO IDEA WHATS WRONG!
Postby 01SolaraV6 » Fri Jul 14, 2006 5:54 am
Hey guys this started 2 Weeks ago I had just got off the highway drove mayve 2kms going around 140 and I stopped at the gas station , and my car was all jumpy I looked at my Tach and the rpms were jumping between 0 and 1k. (my tank was at 1/4)
After i filled it up the problem seemed to be gone.
Last night same thing (just above 1/4 tank) But my car was worse normally it only did this in idle, but now it was jerking the car as i drove, very concerning.
Anyone know what this could be , Bad Gas?, Oilchange, Sensor?
anyone have any idea?
Thanks in advance, Mike
2001 Solara SE V6 (5speed) Silverstream Opal
Loaded
01SolaraV6
Postby WTF?? » Fri Jul 14, 2006 7:04 am
whats mileage on your car? and how much maintenance do you do?
sounds like you need to clean the Throttle Body. Look around in the Tutorial Section to find a thread on how to do this. If this doesnt work, your Idle Air Control (IAC) valve may be going bad- you can have that cleaned too.
Retired... its been fun Image
WTF??
Postby 01SolaraV6 » Fri Jul 14, 2006 8:05 am
I am sitting at 107800KMS, Purchased it at 97000 and have done regular oil changes.
My girlfriend's dad has a Solara didnt need a tuneup till 200000k so i think i am ok for that,
Loaded
01SolaraV6
Postby Wang2k » Fri Jul 14, 2006 10:20 am
vacuum leak or something? Check all your hoses
Wang2k
Postby Turbosolara » Fri Jul 14, 2006 10:29 am
01SolaraV6 wrote:I am sitting at 107800KMS, Purchased it at 97000 and have done regular oil changes.
he is just lucky. please following the suggested tune up schedule.
Postby Hefty » Mon Jul 24, 2006 10:31 pm
i had a very similar issue. I had the throttle body cleaned and it did it one more time and then went away. Shortly there after i threw a CEL code for a faulty o2 heater circuit bank 1 sensor 1. I replaced the sensor with new one from Toyota and car drives like brand new again.
1999 Solara SE V6
2003 Nissan 350Z Track
Hefty
Postby boneezy » Tue Jul 25, 2006 7:26 am
theres a vacuum leak somewhere. my old audi did that and I found out that the electrical tape that i had covering a huge gash in one of the lines came off
1999 SE-V6 5spd
160,xxx miles
boneezy
