SolaraGuy.com • View topic - howl from right front
Postby Jeffrey Olson » Sun Jul 16, 2006 9:23 pm
I just purchased a 99 SE with a 6 cylinder engine. I noticed that when I turn the steering wheel to the right only a couple degrees going above 50 mph, a really low howl that changes with mph vibrates from the right front side of the car. When I track straight or turn the same amount to the left - no sound.
Does anyone "resonate" with that description enough to suggest what it is and what needs to be fixed?
Another sound I get when I hit a bump is a "loose parts" sound. I test drove a Solara in Greeley, CO that had a broken strut and while it is nowhere as loud or prevalent, the clunkety-clunk sound sounds like a younger version. Comments?
Thanks...
Jeff Olson
Martin, SD
Jeffrey Olson
Postby MCOjerry » Sun Jul 16, 2006 9:25 pm
Hmmm...maybe you have an owl or wolf up in there? joking...
Perhaps a belt...belts make noises like that. As for the loose part noises, wow, don't know. Could actually be looses parts.
Postby MCOjerry » Sun Jul 16, 2006 9:26 pm
BTW: Welcome to SolaraGuy!
Postby Jetfixer » Mon Jul 17, 2006 1:04 pm
Check the outer cv joint for wear.
Jetfixer
Postby Jeffrey Olson » Wed Jul 19, 2006 6:46 pm
I was hoping no one would suggest cv joints. Any tips on how to check for wear? I'm a shade tree mechanic, putting a subaru engine in a VW vanagon, but diagnosis is my weak spot...
Jeff...
Jeffrey Olson
Re: howl from right front
Postby toy4x4boy » Wed Jul 19, 2006 7:23 pm
Jeffrey Olson wrote:I just purchased a 99 SE with a 6 cylinder engine. I noticed that when I turn the steering wheel to the right only a couple degrees going above 50 mph, a really low howl that changes with mph vibrates from the right front side of the car. When I track straight or turn the same amount to the left - no sound.
Thanks...
Jeff Olson
Martin, SD
CV joint or wheel bearing most likely for the howling sound. Most likely the strut mount for the loose parts sound.
toy4x4boy
