SolaraGuy.com • View topic - HELP with customizing my emblems
Postby michaelwgng » Tue Jul 18, 2006 8:51 pm
did any one try to change the color.. i got a DWP with gold emblems.. I wanna paint them black.. What kinda black spray paint should i use? and how am i suppose to stick 'em back.. does double sided tape work??
I tried to search but all i found is how to shave emblems.. :o
Mike
michaelwgng
Postby krawzyazn » Tue Jul 18, 2006 8:52 pm
dealer sells them
Postby michaelwgng » Tue Jul 18, 2006 8:53 pm
they r expensive there
Mike
michaelwgng
Suggestion
Postby JMSinMaryland » Tue Jul 18, 2006 9:05 pm
Ebay
JMSinMaryland
Postby Solorange » Thu Jul 20, 2006 5:18 pm
If you want to do it yourself I recommend removing them from the car. Then just buy some black automotive spray paint from autozone and paint them. Also, you will have to buy some more 3m tape to restick them back on the car.
Postby MaxBoostSolara » Fri Jul 21, 2006 6:41 am
has any1 ever tried that spray-on adhesive. i think that should work for putting it back on. if u spray paint it, try n give it a top clear coat or some sort of protectant cuz u wouldnt want it to start chipping away
MaxBoostSolara
Postby ChrYstiE » Fri Jul 21, 2006 6:46 am
MaxBoostSolara wrote:has any1 ever tried that spray-on adhesive. i think that should work for putting it back on. if u spray paint it, try n give it a top clear coat or some sort of protectant cuz u wouldnt want it to start chipping away
i don't think the spray on is gonna be strong enough
08 VW GLI
ChrYstiE
Postby vinnie the sex » Mon Sep 18, 2006 10:38 pm
wat does dwp mean?
vinnie the sex
Postby LatinDragonXJC » Mon Sep 18, 2006 10:44 pm
vinnie the sex wrote:wat does dwp mean?
uhm.........Doesn't Work Properly or Diamond White Pearl.
LatinDragonXJC
Postby PXLpainter » Mon Sep 18, 2006 10:45 pm
DON'T try to use spray adhesive on the emblems - they'll be on the dash of someone's car the first trip down the freeway! ;)
IF you choose to paint your emblems, sand them good first and use a good quality paint. It would be best to use real automotive enamel with a catalyst and shoot it that way - but if you have to use a spray can just make sure you get good stuff and LET IT DRY!!
Good luck! ;)
Vinnie - DWP = Diamond White Pearl (Solara Color)
Postby vinnie the sex » Mon Sep 18, 2006 10:48 pm
sweet thanx
vinnie the sex
