SolaraGuy.com • View topic - Replacing Brake Pads
Postby xsolara33x » Wed Jul 26, 2006 11:38 am
Does anyone have any instructions on replacing brake pads? if anyone has a copy of the haynes manual cna you please post it up? thanks in advance.
raphael
xsolara33x
Re: Replacing Brake Pads
Postby ~Spadwaller~ » Wed Jul 26, 2006 11:50 am
xsolara33x wrote:Does anyone have any instructions on replacing brake pads? if anyone has a copy of the haynes manual cna you please post it up? thanks in advance.
raphael
Its easy switch ones need replacing.
~Spadwaller~
Postby krawzyazn » Wed Jul 26, 2006 11:51 am
hey raph make sure you get oem pads call david for help lol
Postby xsolara33x » Wed Jul 26, 2006 11:57 am
need my fronts replaced.. just called dealership... its 44.10 total... mark, my BRAKE light was on for liek amonth or so, haha, but today as i pulled up to park my ride, the brakes were grinding or something... i wasn't applying the brakes or nething either... i think my pads are DONE... i tried searching the tutorial forum but noone had detail info on replacing the brake pads... thanks again...
raphael
xsolara33x
Postby steve-o » Wed Jul 26, 2006 12:55 pm
xsolara33x wrote:need my fronts replaced.. just called dealership... its 44.10 total... mark, my BRAKE light was on for liek amonth or so, haha, but today as i pulled up to park my ride, the brakes were grinding or something... i wasn't applying the brakes or nething either... i think my pads are DONE... i tried searching the tutorial forum but noone had detail info on replacing the brake pads... thanks again...
raphael
Brake light has nothing to do with pads. It might indicate fluid level low or some booster problem but not pads.
steve-o
Postby xsolara33x » Wed Jul 26, 2006 1:07 pm
i know... its happened to me before, but i really need new pads now... i just added a little brake fluid... when your E BRAKE light comes on, means your fluid is low, meaning you pads are wearing down so its using more fluid or something... anyone have instructions?
xsolara33x
Postby Jai_Jai_Binks » Wed Jul 26, 2006 1:21 pm
xsolara33x wrote:the brakes were grinding or something.
Sounds more like warped rotors if you ask me! Have it professionally checkout when in doubt!
- Jai
Postby shocar4 » Wed Jul 26, 2006 1:24 pm
grinding is your pads not warped rotors......warped rotors will make your steering wheel wobble when braking!
shocar4
Postby Koala » Thu Jul 27, 2006 7:13 pm
When the pads are worn, the pistons will be push a bit more toward the rotors. Your brake fluid level clould be lower because of that. Do not top it off until you replace the pads. If you do, once you put the pistons back into the cylinder, it will cause the fluid overflow.
If you can hear the grind, it could be that the pads are all gone and caliper is grinding on the rotor.
Take the wheel off and check it ASAP. Don't just keep driving.
It will make a groove on the rotor.
MCV20
Koala
Postby krook » Thu Jul 27, 2006 8:54 pm
1. jack up the car
2. remove the wheel
3. remove the bottom caliper bolt 14mm i think
(this bolt holds the caliper to a bracket which is positioned over the rotor's face)
4. tilt the caliper out of the way
(secure it with some wire, or a 3rd hand/limb you may possess)
5. slide the old pad out of the caliper bracket; front and back
6. with a C-clamp, push the piston back into the caliper bore
(have someone check the level of brake fluid at the reservoir for overflow)
7. slide the new pad into place; front and back.
8. replace everything.
this should only take about 5-10 minutes once you remove the wheel.
krook
Postby hskrsolara » Thu Jul 27, 2006 9:58 pm
when you use the c-clamp to push in the piston, remember to leave the pad in so that the piston is uniformly pushed in and the sleeve isnt damaged.
hskrsolara
Postby ~Spadwaller~ » Fri Jul 28, 2006 1:49 am
[quote="hskrsolara"]when you use the c-clamp to push in the piston, remember to leave the pad in so that the piston is uniformly pushed in and the sleeve isnt damaged.[/quote]
you mean the piston boot isnt damaged, right?
~Spadwaller~
Postby hskrsolara » Fri Jul 28, 2006 9:40 am
yessum.
hskrsolara
Brake Pads
Postby Texas Tornado » Mon Nov 27, 2006 3:33 am
Has anyone used or do you recommend EBC Green Stuff or Red Stuff Brake Pads for a 2003 SLE? Or; what brand do you recommend.
I also bought Front and Rear Brembo Drilled Rotors, can't wait until they arrive.
Thanks for the help.
2003 Solara SLE 3.0 V6 - Red
Very clean adding mods.
Mods: TRD Body Kit, Injen CAI, Optima Red Top, TRD RSB, TRD FSB, TRD Oil Cap.
Texas Tornado
