SolaraGuy.com • View topic - Bad Strut
Bad Strut
Bad Strut
Postby Grnarowana » Fri Jul 28, 2006 11:07 am
The mechanic says I have a bad strut on the passenger side.
BTW, with the noise most of you were complaining about the rattling sound could be your strut! so check it out.
The mechanic showed me what was wrong when he put pressure on the front end and i saw the strut pop out on the passenger side like it was loose or something. However, I didn't fix the problem because I wanted to check which sturts are best for the solara and how much would it cost to fix.
I had this problem with this for like a year and put it off and the car still works fine.
ANy suggestions on new front struts?
Grnarowana
Postby Adum-Bom » Fri Jul 28, 2006 11:43 am
sometimes the strut bearing has the rattle noise like its gonna fall out. I think thats what mine has, on the passenger side, and starting on the driver side.
99' SLE V6
My Garage
I can so some pretty SWEETTTTT jumps :)
Adum-Bom
Postby DaTwUnKrAziEpInOy » Fri Jul 28, 2006 11:46 am
it all depends on what you want.....do you want a stock ride ? do you plan on dropping it ? If you're going to stay stock...then go with Kyb struts. If you want a more than stock..go with Tokico. my .02
DaTwUnKrAziEpInOy
Postby krawzyazn » Fri Jul 28, 2006 12:13 pm
still got TRD's forsale
Postby WTF?? » Fri Jul 28, 2006 12:14 pm
^just go to him to buy
Retired... its been fun Image
WTF??
Postby Sleeper » Wed Aug 09, 2006 2:31 pm
Ive got the same problem from the TRD struts
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby AznDragonV » Wed Aug 09, 2006 3:10 pm
i had the same problem so i changed to tokicos...i got mine from ebay
AznDragonV
Postby Jai_Jai_Binks » Thu Aug 10, 2006 8:56 am
DaTwUnKrAziEpInOy wrote:it all depends on what you want.....do you want a stock ride ? do you plan on dropping it ? If you're going to stay stock...then go with Kyb struts. If you want a more than stock..go with Tokico. my .02
^^ what he said, but add to his comments.
Stock ride: KYB, Monroe
Aftermarket: Tokico.
Suggestion
Postby JMSinMaryland » Thu Aug 10, 2006 9:22 am
Go with Toyota OEM struts. Either through the dealership or through me for $200 for 4 struts and 4 springs. Jon.
JMSinMaryland
Postby DaTwUnKrAziEpInOy » Thu Aug 10, 2006 10:36 am
Usualy if you hear rattling or clunking or knocking sound when going over road imperfections, your strut mounts could have gone bad and need to be replaced. or maybe a nut or bolt could be loose somewhere on the suspension.
DaTwUnKrAziEpInOy
Postby bkp_duke » Wed Aug 16, 2006 6:24 pm
Amen on the strut mounts. I've gone through 3 of them and I'm at 106K.
2000 Solara SLE V6, Silverstream Opalescent
TRD Body Kit, Charcoal Leather
TRD Shocks, Struts, RSB, and Air filter
Legal Tint (32%)
bkp_duke
Postby sbsolara84 » Mon Aug 21, 2006 7:41 pm
I"ve been running Tokicos on my 01 solara (dropped with Eibachs) for the for past 2 years.
So far so good, they're definitely stiffer than the stock ones.
I got mine for about $400 and another $400 to install and alignment.
...Ben
sbsolara84
