SolaraGuy.com • View topic - price of a 90k maintenance
Postby udonoogen » Fri Jul 28, 2006 11:33 am
getting new brakes in the back, rotors turned, new timing belt, water pump, oil change ... all the regular 90k stuff
the charge is $575. is this atypical? i trust my mechanic but wow ... that hurts.
1999 V6 SLE, Diamond White Pearl
udonoogen
Postby PXLpainter » Fri Jul 28, 2006 11:53 am
Doesn't sound bad for all that IMO - the Timing Belt and Water Pump alone could run the bulk of that I'd think...
Not Bad
Postby JMSinMaryland » Fri Jul 28, 2006 12:14 pm
Make sure that includes thermostat as well. If so good deal. For thermostat, water pump and timing belt a great deal is $500. If you need your brakes done as well that's it's a REAL fair deal. Jon.
JMSinMaryland
Re: Not Bad
Postby udonoogen » Fri Jul 28, 2006 3:30 pm
JMSinMaryland wrote:Make sure that includes thermostat as well. If so good deal. For thermostat, water pump and timing belt a great deal is $500. If you need your brakes done as well that's it's a REAL fair deal. Jon.
is changing the thermostat necessary? how often does that break?
udonoogen
Postby NeFaRiOuS_SLE » Sat Jul 29, 2006 9:53 am
Where do you live? Because I got the 90k done for $270 and the timing belt for $189 at Puente Hills Toyota (but then again my friend kinda hooked me up; if you're in the SoCal area I can try asking).
Postby JAYDEE23 » Fri Aug 04, 2006 3:12 pm
its a fair price....labor hrs and parts for water pump and timing run about $400 according to my mech's books..new brakes..turned rotors and oil change for 175..ehh not bad...
JAYDEE23
Postby bassthrive » Sat Nov 11, 2006 10:31 am
I was just quoted $800 for timing belt, drive belts, cam/crank seal and water pump.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby rec » Sat Nov 11, 2006 10:41 am
dam thats expensive just to change a couple belts. I know a guy who did it for $$20
Mine is black.......
rec
Re: Not Bad
Postby onefiend » Sat Nov 11, 2006 11:58 am
I'm wondering about this myself. My friend who bought my gen1 off me asked about the thermostat longevity. I gave her a blank look. lol
2007 Camry SE V6
onefiend
Suggestion
Postby JMSinMaryland » Sat Nov 11, 2006 2:04 pm
It's about saving time/headache/money if you get it done at the same time. If you wait for it to go bad you'll pay a lot more. Technically not all timing belts and water pump go bad at 90k, it might last you 100k or 120k or even longer. Most of us aren't willing to wait until they go up to find out they needed to be replaced because you never know where you'll be. I replaced my clutch when it started to slip because I didn't want to have to worry about how much longer it could last. Just my .02 cents. Jon.
JMSinMaryland
Postby Solorange » Sat Nov 11, 2006 3:03 pm
I think thats a good price inlcuding the timining belt and water pump
Ive been quoted between $600 to $700 and that is just the water pump and timing belts
Postby steve-o » Sat Nov 11, 2006 4:31 pm
My mechanic charged me 350.00 for the timing belt and water pump on my '96 camry, then we added both front axles, 4 spark plugs, an oil pump, changed the o'rings around the distributer and timing gasket, the belts and an oil change, that brought it to 850.00 cash.
He won't turn rotors any more. He'll replace them. Says it's not worth it to turn. Total cost for 2 front discs and the rotors was 220.00.
If that's any indication. Your getting a good deal, provided its good work..
steve-o
Postby 99V6solaraSE » Fri Dec 01, 2006 11:48 am
i just hit 90k .. and i know i probably wont have enough money to get the maintenance done right now...
is it bad if i wait too long??
i just got my oil changed and new rear brakes and rotors.
99V6solaraSE
Postby Midias » Fri Dec 01, 2006 12:06 pm
99V6solaraSE wrote:i just hit 90k .. and i know i probably wont have enough money to get the maintenance done right now...
If your timing belt goes it will most likely take your engine with it other thajn that you should be good.
Postby steve-o » Fri Dec 01, 2006 12:07 pm
I learned my lesson w/ timing belts. Yeah it could go another 15-20k but it could go tommorow. Just have to hope when it does break your in a convenient location. piece of mind..
steve-o
