SolaraGuy.com • View topic - starting in 2nd?
starting in 2nd?
starting in 2nd?
Postby sillygrrrl » Sun Jul 30, 2006 1:34 pm
is it bad that i can EASILY get the car- from completely stopped- into motion again starting in 2nd gear?? does this mean anything like needing a new clutch?
sillygrrrl
Postby dominoSLEV6 » Sun Jul 30, 2006 2:20 pm
Nope, perfectly normal. You should ahev to be slipping the clutch some amount with a little overrev, not like a COMPLETELY normal start, but I get to a slow roll at stop signs, basicly to a stop and go in 2nd all the time. Theoreticly you should be able to start your car in any gear, though I wouldn't recommend anything above 2nd.
It really doesn depemnd on how easily you're getting it to start in second, it could need a new clutch, and it won't start easily in 2nd with a new one, but still, IW ouldn't worr yabout it.
-chris
dominoSLEV6
Postby NeFaRiOuS_SLE » Mon Jul 31, 2006 10:33 pm
Yeah I won't worry either; this is usually the better way to start in motion when you're on slick roads to prevent wheelspin, but hell, it's summer.
Postby Mole » Tue Aug 01, 2006 10:38 am
my friend lost his 2 first gears in his vw and had to start in 3rd each time.
he got real good at it too
