SolaraGuy.com • View topic - Water leaking inside...
Postby Omes01SLE » Thu Aug 03, 2006 5:45 am
I went to my car the other day to literally find a puddle of water in the driver's footwell, as well as behind me in the backseat. The carpet is literally drenched - the water is not coming in from outside (as it has not rained in weeks), my beleif is that it is coming from the A/C unit somehow.
I don't know if the original water drain plug has been blocked and now the water is overflowing inside, but when I look under the car I can see the water droplets formed right under the driver/passanger side.
The other negative of this, is that I guess there are electrical wires running under the carpet and now with the water all my bulbs are shorting out!
Any help/info would be appreciated.
thanks.
Omes01SLE
Postby DatSRBoi » Thu Aug 03, 2006 5:56 am
If you have a moonroof then its that.
Re: Water leaking inside...
Postby Gregtrd » Thu Aug 03, 2006 12:13 pm
Omes01SLE wrote:I went to my car the other day to literally find a puddle of water in the driver's footwell, as well as behind me in the backseat. The carpet is literally drenched - the water is not coming in from outside (as it has not rained in weeks), my beleif is that it is coming from the A/C unit somehow.
thanks.
check if it smells like radiator fluid, it could be that your heater core went bad.
Gregtrd
Water
Postby PDX SuperSolara » Thu Aug 03, 2006 1:33 pm
Well if it has not rained, it could not be the moonroof anyway. Coolant indicates a heater core leak. Real spendy. Water means the drain for the A/C is plugged. You can usually unplug these from under the car by running a coat hanger type wire through the tube to dislodge the crud plugging the drain tube.
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
PDX SuperSolara
Postby Omes01SLE » Thu Aug 03, 2006 2:01 pm
Do you know where approx. the drain for the AC is under the car?
Omes01SLE
