SolaraGuy.com • View topic - PO440 Help please?
PO440 Help please?
PO440 Help please?
Postby Nyyankees3511 » Mon Aug 07, 2006 4:35 pm
Well i was driving home and i got a check engine light last night. Reset it this morning and it took a while for it to come back had it check they said its code PO440 Evap. I then had a pro check it out he said the flow was low. What do you think it is? Thanks
Nyyankees3511
Postby WTF?? » Mon Aug 07, 2006 5:57 pm
Retired... its been fun Image
WTF??
Postby Nyyankees3511 » Mon Aug 07, 2006 6:23 pm
Thanks wtf. Those are different codes but similar problems. Usually what does P0440 alone mean? The second guy that check it out used a beefy obd2 checker with all kinds of chips and stuff and it said the flow was low?
Nyyankees3511
Postby WTF?? » Mon Aug 07, 2006 6:32 pm
http://www.solaraguy.org/viewtopic.php?t=16121
P0440 – EVAP System Malfunction
· Vapor pressure sensor malfunction
· Fuel tank cap cracked, damaged or incorrectly installed
· Vacuum hose blocked, cracked, torn or disconnected
· Hose or tube blocked, cracked, torn or disconnected
· Fuel tank damaged
· Charcoal canister damaged
Honestly I dont know what the hell the guy is talking about when he says "flow is low"..... WHAT flow??? LOL
anyway the list above should tell you a brief description of what the CEL Code defines. Basically I just had my gas cap pressure tested (failed once, passed once) and went to buy a new gas cap from the dealers for $20.... ever since no problems
first off, just make sure your gas cap is on tight (at least 3 clicks)... drive it around for a while and fill up another tank to see if it comes up again
good luck
WTF??
Postby Nyyankees3511 » Mon Aug 07, 2006 6:39 pm
Ill try that. It could be the vsv right? Wheres the pressure sensor located? The good thing is i still have my totaled car and i can switch any parts i need. Lol thats what that lil comp that he connected to my car said, it said the flow through the lines was low.
Nyyankees3511
Postby Solorange » Tue Aug 08, 2006 7:25 am
Definatly replace your gas cap first.
Postby Nyyankees3511 » Tue Aug 08, 2006 7:47 am
Ill try that first.
Nyyankees3511
Postby Jeffrey Olson » Thu Aug 10, 2006 10:41 pm
I got the 440 code too. I was driving from California to South Dakota and got off in Salt Lake and found an auto parts store, borrowed their code reader, and they printed out what the code meant. The counter guy recommended I start with a gas cap. I cleared the code, installed the gas cap, and was on my way.. That solved the problem...
Jeff...
Jeffrey Olson
Postby WTF?? » Thu Aug 10, 2006 11:11 pm
^its great when it works out that way huh...
get an error, find out wut it is, get the part replaced, and ur done! :bday:
WTF??
Postby Nyyankees3511 » Fri Aug 11, 2006 5:47 am
I replaced the gas cap and it hasnt come back.
Nyyankees3511
Postby Solorange » Sun Aug 13, 2006 12:59 pm
You guys are all lucky! I got the code PO446 and it said nothing about a gas cap. So I spent the money on the charcoal canister and it really was my gas cap too.
