SolaraGuy.com • View topic - Are there any custom Whiteline FSB brackets for Gen1?
Postby PTSOLARA » Mon Aug 07, 2006 8:22 pm
For 3 years, I have been enjoying the additionaly control with the FSB whiteline for my Gen 1 Solara. The bad thing is that i have the stock front brackets to hold this FSB .
The standard brackets break every now and then. I have replaced two times already. i hate to do this again (it just broke again today)
Does anyone out there know of a BIGGER brackets so i don't have to replace this every time. If so, please provide a place to get it and the part#.
1999 Solara SE V6 Red 5 speed Sports Ed.
Tokico/Eibach Whiteline FSB/RSB Ingen
PTSOLARA
Postby TheTamago » Tue Aug 08, 2006 4:24 am
I do believe Whiteline does carry custom FSB brackets. Just find the size of the white FSB which is 22in?? Might find it in their catalog or send an e-mail to them. Might take a couple business days for a reply though. I'm kinda doing this but my suspension setup has been put on hold so this is the only info i can relay to ya. The custom brackets with super pro poly bushings.
TheTamago
Postby SleeperSolara » Tue Aug 08, 2006 5:57 am
The standard brackets break on you????? :o
Pictures man, that would help.
I don't see how they would break on a front sway bar....... :-?
I've had my TRD RSB in and nothin' broke on me yet.
Postby StockSolara » Tue Aug 08, 2006 5:38 pm
SleeperSolara wrote:The standard brackets break on you????? :o
This only happens to the people with Whiteline FSB not the TRD RSB
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SleeperSolara » Tue Aug 08, 2006 7:40 pm
Oh really.... :o :o
Why is that??
I'm shocked cause i was about to get a Whiteline FSB..... :-?
But pictures would still help though.
Pictures for Whiteline FSB issues
Postby PTSOLARA » Tue Aug 08, 2006 9:12 pm
Here are some pictures of my current iWhiteline FSB ssue. This has happened a few times already. i need stronger brackets to hold these bigger bars in place.
BTW, i have emailed someone at Whiteline about the brackets a while back but they responded that they have nothing for my car.
PTSOLARA
Postby MentatGom » Tue Aug 08, 2006 11:16 pm
What bushing are you using? My poly bushings that came with my bar look smaller... perhaps the larger bushing and a little over torquing the bolts is causing the breaks. The brackets only take 14 ft/lbs of torque.
MentatGom
Postby TheTamago » Wed Aug 09, 2006 12:08 am
Appreciate my services cause you'll love my e-mail:
Contact: Wayne Cunningham [wayne@whiteline.com.au]
Thank you for your e-mail and for purchasing a Whiteline sway bar.
The sway bar # BTF38 is supplied with the D-bushes to allow fitment of the sway bar using the OEM mounting brackets. The issue that you have mentioned is not something that has been bought to our attention as being an issue. What we do have is the # KS6 (universal saddle kit) & # W0400-size (D-bush kit to suit the KS6 saddles) available for separate sale if they are required.
These can be purchased through our exclusive US distributor, there details are as follows:
Global Performance Parts
4554 - 128th Ave
Holland. MI 49424. USA
Ph: 616 399 9025
Fax: 616 399 9174
Web: www.globalperformanceparts.com
I hope this helps you.
Regards,
Wayne Cunningham
Technical support
Go Flatout with Whiteline Automotive
* Email: wayne@whiteline.com.au
-----Original Message-----
Sent: Friday, 27 January 2006 7:06 PM
To: Support
Subject: Whiteline Front Sway Bar BTF38 Camry/Solara Application
Hello Whiteline, I recently purchased the front sway bar for a Toyota Solara 2000. I found out that a another Solara owner had issues with your front sway and contacted you for the fix of the fitment issue with the OEM brackets to secure the bushings with the oversized bar onto the links. I believe they’re the OVERSIZE Clamps?
Here is the reference link
http://www.solaraguy.org/viewtopic.php? ... t&start=15
Link to my upgrade page for the whiteline sway bar
http://www.solaraguy.org/viewtopic.php?t=22797
Need them with in a week’s time by Feb 10 at the latest.
TheTamago
Postby pythonjosh » Wed Aug 09, 2006 1:19 am
How come that FSB looks blue? My whiteline is silver.
It was a pain getting the bracket over the bushings, but no issues with mine as of yet. Only had it a couple thousand miles now.
pythonjosh
Postby SleeperSolara » Wed Aug 09, 2006 11:41 am
Dang man. :o
That is a shock too me. :o
Thanks!!
Postby PTSOLARA » Wed Aug 09, 2006 9:40 pm
TheTamago, thanks for the info. I will contact that vendor first thing in the morning. i can hear subtle noise now that the brackets are broken.
To answer pythonjosh's question, i was involved with a major group buy a few years back in one of the older camry forum. Both my FSB and RSB from whiteline are blue.
Maybe Whiteline modified the design and changed the color? But blue works well for my car since it blends in with my blue tokico shocks (that is, if people care to look under my car).
PTSOLARA
Postby gnaw_divad » Fri Oct 17, 2008 7:06 pm
hey, just wondering if you had any updates on your issue? and if you did end up replacing the brackets with the ones from whiteline.
I've probably had my whiteline swaybars for over 5 - 6 years now and I've broken the brackets twice now as well. Just curious if everything worked out, I'm definitely looking to get a pair for myself.
gnaw_divad
Postby unbalancedwood » Fri Oct 17, 2008 7:50 pm
i think the brackets are fine, it would probably be easier to locate the bushing made for a bigger bar...
unbalancedwood
Postby gnaw_divad » Fri Oct 17, 2008 8:03 pm
i do have the larger bushings for the thicker bar. I have the bushings that originally came with the whiteline swaybars but only the stock brackets. It doesn't seem like everyone is having this similar issue, but there seems to be a few of us that just keep getting broken brackets.
gnaw_divad
Postby cartang » Sat Oct 18, 2008 3:58 am
I broke them 1 time , I switched to Energy susp. brackets ( 25mm I think I dont remember.) I Have for 6 years
cartang
