SolaraGuy.com • View topic - Help: Disabling Alarm
Postby happy_aggies » Mon Feb 24, 2003 11:59 am
Howdy!
Does anyone knows how to disable Alarm for my Solara?
As y'all know, my Solara has been wreck.
The alarm did not function properly,
everytime I press Unlock, the alarm will goes off.
I have to go into the car and start the engine to shut it off.
The same thing happened if I use the key to unlock,
the alarm will goes off a soon as I unlock it.
Note: The passenger side door can't be open/moved.
Thanks y'all!
happy_aggies
Postby Yanks0114 » Mon Feb 24, 2003 2:25 pm
Check on teamsc3.com. I posted for you, but basically you are going to:
press unlock on the key fob
Put the car in the "on" position
Press the red hidden switch for 5 seconds.
The led to the left of your steering wheel should light up to confirm successful disarming. Its technically called valet mode.
Postby happy_aggies » Mon Feb 24, 2003 2:46 pm
Thanks Yanks0114!
iI'll give it a try.
happy_aggies
