SolaraGuy.com • View topic - 99 and 00 brake differences?
Postby Nyyankees3511 » Thu Aug 10, 2006 4:40 pm
I was going to switch out my brake pads from my old totaled car which is a 2000 and they didnt look the same as the 2000s? Are they different or am i just a retard?
Nyyankees3511
Postby Sleeper » Thu Aug 10, 2006 5:11 pm
which brake pads? I had a problem with my rear brake pads. Apparently there are two different sizes for different year cars for gen 1.
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby Nyyankees3511 » Thu Aug 10, 2006 5:14 pm
I tried putting 2000 rear pads in my 1999 and they seem different.
Nyyankees3511
Postby Jon11582 » Mon Aug 14, 2006 8:30 am
I thought they were the same. But it shouldnt matter because....
You should be using NEW brake pads. Theres never a time you should throw on used brake pads. Those brake pads are already worn into the rotors on the totalled car and your rotors wont mate well and will more than likely chew them up in short order.
You could bring over both the pads and rotors, in which case it would be OK.
2000 Black Solara SE
Jon11582
Postby DatSRBoi » Mon Aug 14, 2006 8:38 am
If Im correct there is a difference among the cars brake. Mines a 2000 and I have to use a 2002 If I remeber for the rear because the 2000 didnt fit. Its been awhile but there are a difference.
Re: 99 and 00 brake differences?
Postby BabyFaceFinster » Tue Aug 15, 2006 9:41 am
Nyyankees3511 wrote:I was going to switch out my brake pads from my old totaled car which is a 2000 and they didnt look the same as the 2000s? Are they different or am i just a retard?
99 & 00 rear pads are different. I got stuck with a set of Axxix pads for a 99. Interested. I'll send em' for shipping. I just don't want to dump them
One BAD-A$$ rare solara convertible!!!
BabyFaceFinster
