SolaraGuy.com • View topic - 60,000 mile mark
60,000 mile mark
60,000 mile mark
Postby st.augsolara02 » Sat Aug 12, 2006 12:08 pm
well guys im coming up on my 60,xxx mile mark on my 02 and am about to start the maintaince..i was just wondering what some of you guys have done for the 60,000 mile maintaince requirements? im gonna change to NGK plugs, new serpentine belt cuz its gettin some surface cracks, cleaning the TB, oil change, and an alignment and rotors turned just to be safe..anything else i should look into or that you guys did that im missing??
So long Solara...Hello IS300!!!
New Project: '01 Autumn Sky Pearl IS300
* tien coliovers, 5% tint, SRT intake, HKS Carbon-ti exaust, 7" touch screen DVD, 2 12" Kicker Comp VR's
st.augsolara02
Postby SolaraBlue » Sat Aug 12, 2006 12:44 pm
trans. flush maybe. im at 50k so soon enough i'll be having to do some of this stuff too.
Postby onefiend » Sat Aug 12, 2006 3:01 pm
this has been discussed alot here at SG, if you do a search it'll show alot of threads on service and maintenance.
2007 Camry SE V6
onefiend
Postby Jackass-Jeff » Sat Aug 12, 2006 3:31 pm
Oil Change
Trans Fluid CHANGE (our fluid doesn't need a flush)
Brake Fluid
Powersteering Fluid
Coolant change (USE TOYOTA COOLANT! FAILURE TO COMPLY WILL RESULT IN A LEAKING WATER PUMP)
Drive belts if worn (I've already gone through 2 sets @ 70k...)
Engine air filter
Plugs are good til 90ish... change them early if you think you need to... heh.
ROTORS should be done w/ brakes... no need if they aren't vibrating/pulsating when braking @ high speeds.
Suggested maintenance, not required:
Drain and Refill Tire Air
Flush blinker fluid
Drain and refill cabin air
Jackass-Jeff
Postby NeFaRiOuS_SLE » Sun Aug 13, 2006 11:45 pm
Also a good idea is your valve adjustment... It was supposed to be done at 60,000 miles, but my car didn't have it done (at least according to the stealership), but then again I got my car with 82,000 miles on it and I'm too broke to get it done, but who knows; that probably explains my gas mileage.
Postby QuickSEV6 » Sun Aug 13, 2006 11:55 pm
Jackass-Jeff wrote:Suggested maintenance, not required:
Flush blinker fluid
Some items you forgot:
- Adjust the muffler bearing
- When you drain blinker fluid, you might consider replacing with Halogen fluid or perhaps the much more expensive HID fluid.
- Remove dead bugs from windshield and replace with live bugs
- Some of the more difficult maintenance jobs require special tools. You may need to go to hardware store and get a left-handed screwdriver and a metric hammer.
- A lot of the lighting projects are pretty cool. I recommend changing the color of your headlights to a brilliant bright red. It looks very cool to on-coming traffic.
