SolaraGuy.com • View topic - why am i losing sooo much oil!?
Postby pervo » Thu Aug 17, 2006 10:00 pm
3 quarts in 750 mi (driving 350 mi one way then back)
previouse to this i drained my oil and had about half a quart left!
pulled the plugs to do a compression test
compression checks out on all cylinders
4/6 plugs had moderate to heavy white deposits
(cylinder 1,2,4,6)
very surprising since i just had the plugs replaced due to misfiring 3 months ago
also having error codes from the EGR system, replaced the egr vsv and seem to need to replace the valve possition sensor
not to confuse w/ the egr system just including the info incase its pertinant
realy worried here :(
pervo
Postby ~Spadwaller~ » Thu Aug 17, 2006 10:10 pm
maybe your head gasket is leaking
~Spadwaller~
Postby Turbosolara » Thu Aug 17, 2006 10:20 pm
was your compression ratio good? when you floor your car, did you see smokes?
if you dont see somke and compression raitio is good, than i would say your engine has some vents was clogged that build too much internal pressure and shot out the engine oil. (check if your throttle body is dirty and greasy)
Re: why am i losing sooo much oil!?
Postby DatSRBoi » Thu Aug 17, 2006 10:21 pm
pervo wrote:3 quarts in 750 mi (driving 350 mi one way then back)
(cylinder 1,2,4,6)
Sorry man. I needed some oil so had to take some of yours.
Postby WTF?? » Thu Aug 17, 2006 10:31 pm
^i knew sumone was up to no good!!! :bad-words: LOL jk
Retired... its been fun Image
WTF??
Postby pervo » Thu Aug 17, 2006 10:31 pm
smoke can be seen sometimes when i start the car
pervo
Postby WTF?? » Thu Aug 17, 2006 10:32 pm
^what color smoke? do a search on this forum and you might be able to find the solution
WTF??
Postby pervo » Thu Aug 17, 2006 10:55 pm
well i already know its either a valve job or a piston rings but the compression was fine?
the hanes manual doesnt explain how to do a valve job and i just dont have the money to give the dealer
so its DIY for me
id rather be more educated tan just tear everything apart
as for the smoke it was very faint blue.... but i havent seen it in a while
gotta deal with it because im certain it is what f-ed up my egr system
pervo
Postby Turbosolara » Thu Aug 17, 2006 11:17 pm
it is quite normal to see light smoke in the moring starting up.
does your valve making ticking noise? if the piston ring is bad, you would have a bad compression raito and you would see colorful smoke when you floor it
Postby dominoSLEV6 » Sat Aug 19, 2006 11:45 am
Dude, chill, it's just the oil gnome. Set a bear trap and you might be able to catch him, otherwise you're SOL.
-chris
dominoSLEV6
Postby pervo » Sat Aug 19, 2006 2:24 pm
well for those who car my engine is gone, filled with sludge
pervo
Postby Yanks0114 » Sat Aug 19, 2006 5:12 pm
pervo wrote:well for those who car my engine is gone, filled with sludge
Is toyota taking care of the sludge problem?
Postby pervo » Sat Aug 19, 2006 6:59 pm
ill let you know, dealer was closed when i discovered this
id encourage all 98-02 toyota owners to open up there valve covers and take a look
never would have imagined the nightmare this solara has become in the last year
pervo
