SolaraGuy.com • View topic - Weird problem with dome light, Please help?
Postby hra » Wed Aug 23, 2006 7:46 pm
I have had this problem for a month with my 99 SLE V6, the dome light will not light up with keyless entry nor when I open the doors. But it works when I push the button. I checked all the fuses and all are ok. Any suggestion would be much appreciated.
hra
Postby RichD978 » Wed Aug 23, 2006 7:49 pm
take apart the fixture so you can test it with a meter
RichD978
Postby NeFaRiOuS_SLE » Thu Aug 24, 2006 1:49 am
Which one, the back one over the center of the car, or the map light near the visors? The ones near the visor don't respond to the doors, even though it'll be a dream come true if that were the case.
Postby pythonjosh » Thu Aug 24, 2006 4:20 am
RichD978 wrote:take apart the fixture so you can test it with a meter
Or just a simple hot wire tester will suffice for this case as well.
pythonjosh
Postby Bravefan » Thu Aug 24, 2006 5:14 am
I've had the same problem with my 99 SLE. I installed LEDs under the dash instead of fixing it.
Bravefan
Re: Weird problem with dome light, Please help?
Postby Jai_Jai_Binks » Thu Aug 24, 2006 7:51 am
hra wrote:I have had this problem for a month with my 99 SLE V6, the dome light will not light up with keyless entry nor when I open the doors. But it works when I push the button. I checked all the fuses and all are ok. Any suggestion would be much appreciated.
if your referring to the lights in front on your (where the sunroof controls)are located - then these do not respond to doors and more like map ligths. The ones behind you (in the middle of the headliner) are the ones that respond to doors.
If its the latter then this is for you.
Locate the black rubber like thingie that is by the body of the car. Its the sensor below the door latch that secures the door to the car (its on the body of the car - not the door side when the doors are shut). See if you can open the rubber thingie and inspect the sensor...I sprayed wd40 on it and depressed it in a few times and you will be able to see how this works with the inside lights. If nothing is going on..then you need to replace the sensors.
Postby hra » Thu Aug 24, 2006 4:11 pm
Thank you so much guys, I was so stupid that I never realised that bulb is behind the sunroofn I was confused with the map light.
hra
