SolaraGuy.com • View topic - brake squeak after new pad
Postby S99Solara » Sat Sep 16, 2006 7:52 pm
Hi,
I just installed new OEM pads (front and rear) on my car. Whenever I brake driver side squeaks 80% of the time. The rotors has been resurfaced, I used high-temp silicone on the pad and the shim. I just cant' figure out what is causing this squeaking sound. Any help would be apperciated.
06 4Runner V8 SE
98 1MZ-FE Camry
SOLD! 1999 SE V6 5 Speed,Clutch Masters Stage 2 Clutch Fidanza Lightweight Flywheel, Tein / Tokico, Philips power2night GT150 H4, TWM Shortshifter, Optima Red Top Battery, TRD RSB
S99Solara
Postby Jon11582 » Sat Sep 16, 2006 8:35 pm
Its normal while the new pads take the shape of the rotor.
Squeaking should go away by 500 miles or so.
2000 Black Solara SE
Jon11582
Postby S99Solara » Sat Sep 16, 2006 8:41 pm
That is what I was thinking at first when I got it installed, but I have about 800 miles already.
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Postby Gregtrd » Sun Sep 17, 2006 10:13 am
make sure that the shield that go's around the rotor is not to close the rotor, if so bent it away from it.
Gregtrd
Postby bassthrive » Sun Sep 17, 2006 8:10 pm
got the same problem. mine arent oem, though they are ceramic. i tried high temp grease, anti-sieze, disc brake quiet (rubbery goop), shims on, shims off - all these "remedys" worked for about 800 miles, but the squeal always came back.
discs are solid brembos and are rather new. i am tired of working on them without any appreciable results so i will probably get a pro to resurface the rotors and install oem pads.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby variant » Mon Sep 25, 2006 10:28 pm
I have the same problem 1000+ miles on new pads/not oem.
variant
Postby udonoogen » Mon Sep 25, 2006 10:59 pm
make sure theyre not dirty and theres a pebble in there creating a symphony
1999 V6 SLE, Diamond White Pearl
udonoogen
Re: brake squeak after new pad
Postby lightear » Mon Sep 25, 2006 11:06 pm
S99Solara wrote:Hi,
I know this may sound stupid, but did you guys apply a lot of the silicone thingy? My friend like literally lavished the back of the pad with it and I've had no problems.
Edit: Actually, remembering back to the time when I had itinstalled, my friend had put soooo much that it was goo-ing out of the brakes for awhile.
lightear
Postby sbsolara84 » Mon Sep 25, 2006 11:14 pm
I have the same problem and everything was done at a shop. i just kinda got use to it.
sbsolara84
Postby bassthrive » Tue Sep 26, 2006 11:45 pm
lightear wrote:I know this may sound stupid, but did you guys apply a lot of the silicone thingy? My friend like literally lavished the back of the pad with it and I've had no problems.
Tried it all. High temp grease, anti-sieze, the blue disc brake quiet, the red stuff - the vibration deadening properties go away after a few hundred miles.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Sol-Toy » Wed Sep 27, 2006 9:11 am
Mine squeek too...nonOEM and over 1k on them. I put a ton of anti-squeek on and the squeel is less dramatic — still there though.
2013 WRX Wagon Premium in crystal black silica - current
2012 RAV4 S - Wife's
2000 Solara 1mz - sold after recording 160k mi
https://www.instagram.com/andygriesemer/
Sol-Toy
Postby DrakkkarDarkbladE » Wed Sep 27, 2006 9:44 am
My suggestion is the same as the others, the grease is what stops the squeaking. I installed the breaks on my car and never had any squaking and this was with some crappy 3rd party grease from autozone.
Apply the grease to the whole back side of the brake pad (the side that the piston pushes against).
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
